apctjb
- Jun 16, 2020
- 502
30 Aptos 375W; 3 parallel strings of 10 in series.how many strings and panels do you have running?
Wow! That's a crazy good dealPricing before shipping attached.
Dude! That's a good price. I'm running out of excuses.Pricing before shipping attached.
No, that's before shipping. It would be best to get a DDP airfreight quote for your location.Dude! That's a good price. I'm running out of excuses.
Is that shipped?
Imagine if they were readily available with local North American stock and you could just buy one with a few day shipping. You would be in big trouble then.Oh boy, I gotta get back outside, you guys talking all day about the 12kW SRNE are going to temp me into a purchase...I told myself to WAIT... Hey if @1201 gets a pair of the 12kW and posts about their set up, maybe that will keep me distracted from buying a pair...DSAM...DSAM..DSAM...
I've sent a message to borick asking how much shipping to me is.Oh boy, I gotta get back outside, you guys talking all day about the 12kW SRNE are going to temp me into a purchase...I told myself to WAIT... Hey if @1201 gets a pair of the 12kW and posts about their set up, maybe that will keep me distracted from buying a pair...DSAM...DSAM..DSAM...
Exciting!I've sent a message to borick asking how much shipping to me is.
What's the weight difference between the 2?Srne: 24kw vs 20kw for growatt
Likely about $1000 cheaper for two
Same work modes as growatt but better menu system
Well I was chatting with an SRNE rep (Abby) before I purchased my ASPs [ and SRNE stopped selling direct to consumer for small orders, don't worry Borick that I've recommended is supported by SRNE for support / warranty is neeeded ] while she was at a conference in Texas with some others from SRNE and she said they are working to develop a larger US presence/footprint. ... So maybe soon.Oye. There I was set on the NHX 10k and then the HES 12k comes along with zero export and no megarevo related quirks. How long will it be before the HES 12k becomes easy to buy without having to go to an Alibaba/Express seller I wonder.
Srne 92.5lbs growatt 107lbsWhat's the weight difference between the 2?
higher PV input than the 12k SRNE - how much higher? (curious)Growatt:
Supports higher pv input
Growatt can use 15kw total, srne says 6600+6600 , so 13.2kwhigher PV input than the 12k SRNE - how much higher? (curious)
are they the same voltage limit VOC?Growatt can use 15kw total, srne says 6600+6600 , so 13.2kw
That's a great chart!
Thanks! I'll update the chatThat's a great chart!
To help further populate, hopefully.
pg 47 of the manual touches on RSD, it looks like it utilizes a signal from the RSD device on the dry contact port.
Pg 56 shows a 5 second overload greater than 125% output, 15KW; I'm speculating it's 24KW for 1 second based max peak power.
Noise is less than 60db (loud).
They need to do better at listing other important specs.
I like the 3 MPPTs for the Growatt and Midnite, I wish my ASPs had 25A MPPTs so I weren't clipping with my NE Solar in 2P.
If it's anything like the ASP there will be no issues. (Battery is not accurate because I didn't feel like soldering UART leads for the 4th pack after work).I wonder about the solar assistant compatibility too.
Not sure, was quoted $1580 and the ddp cost of 10 sets is 1298USD for the SEI 12kW.Hi does anyone know if the sei 12k and hesp 12k are the same inverter?
