So my overnight work has been postponed so Ive made it home with enough sunlight to reinstall the pack.
Id left the pack this morning connected in parallel but removed the power supply and charge leads so any microvoltage differences would hopefully level out across the pack
Its been 12 hours since i removed the charger and I've just checked each cell manually, disconnected from the parallel group with a multimeter each cell read dead on 3.64v not quite 3.65 but the power supply had stopped outputting current and read battery voltage as 3.65v this morning with 0 amps being drawn so I considered this balanced.
I've re assembled the pack in to 16s in a different order to last time with no load or charger attached and after an hour or so this is what the chargery bms shows.
Ive already got cell 9 climbing above the rest Is this normal?
Climbing above the rest or settling less quickly? If you balanced to 3.64, it would appear all cells are settling as would be expected.
