Okay, first post to this forum ever, hopefully I'm not hijacking this post.
I'm new to lifepo4. I've got x4 280ah cells from the same manufacturer as mentioned in this post; genfangbattery.com/products_en.html
I discovered the manufacturer via the QR codes, however the codes do not take me to any specific product information, just the website.
I have gathered supplies for combining my cells into a single 12v battery, but am doing more research on them before I actually hook them up or start using them.
I have a few bits of confusion I thought someone could help with;
- Does having a properly programmed MPPT charge controller negate the need for a BMS? If not, why? I haven't read anything about this so far one way or another.
- Also, I can't find battery specs on the manufacturer's website (listed above) as a guide for how these batteries should specifically be programmed. The videos and pages I've read through so far says to get exact specs from the manufacturer for programming. Since these are the same as what others on this post have purchased, are the specs you have applicable to my cells?
Thanks
