Sixtysix 280ah Cells from Deligreen
I reread Steve's post and he's talking about working with separate cells.
That only makes sense to me for matching.
And I am losing interest in matching.
But I think it makes sense to discharge all cells completely before top balancing.
I am still working out how to charge and discharge using .2C to .5C.
What do you think causes the resting voltage effect? I didn't say is because I am guessing.
Take a look at the discharge curve.
They live in the flat part between the knees.
That’s my guess. The lack of memory effect is a fact.
Now that I have the facts I can move on.
My charge limits will be on the straight line between the knees.
Time to play with my new toy that I mounted on the wall above my workbench.
I was thinking about making up cables as well. I think this is a very good idea. I am working on the wood and threaded rods to tighten it all together as I slowly progress along. 32 280Ah batteries are a physical challenge to move about and support at 380 plus pound pack weight! I am working with 16 at a time but still 190 plus pounds. reinforcing the shelf also.
I got tired of rearranging cells and I have 4 batteries so the cables will be used a few times.
Charging/discharging serial works better but when I top or bottom balance I need to switch to parallel to get the knees
I just got some selves to hold my batteries. They claim to hold more weight than my batteries.
But it hurts me to imagine the top shelf giving way and sending all 4 of my batteries crashing to the ground.
yes, I bought 6 3/8 inch x 36-inch threaded rods and washers nuts to make compression ends to keep the cells together when charging and discharging them. today I will work on the plywood and threaded rods to make up the compression jig. I am thinking about adding some old angle iron from bed frames outside the ends of the plywood for a little more reinforcement. standard procedure -- make it stronger than you need. thanks for the info -- I will be working on it daily if the wife does not tie me into other honey doo's.
If something goes wrong there is tremendous expansion force . I now doubt that it can be stopped economically . I would put some steel on and try to get something holding the centers. There are 5 stainless 3/8ths rods holding that and it just buckled out . All the force went on the edges .Its 5/8ths nylon cutting board. Suprisingly the cells still work fine.
I'm wondering where this chart was obtained . Its pretty right I think top and bottom but not so sure about the green bit.It emphasises however that 20 to 80% state of charge is 0.100 volts. 100 millivolts on a single cell. Hard to pick with a multimeter.
that chart was sent to me from the vendor from China who sold me the 2nd batch of 32 Lishen 272Ah 3.2v cells. the Electrodacus balances to 3 decimal places and my 1st 2P8S 24-volt bank has a resting delta between cells of 8-10mv.
today it is snowing so no real production in the snow I think I am getting about 10 watts when I sweep the snow off the 2 250 watt panels but was getting 440 watts when the sun was shining 2 days ago. this vender said you should up an insulating sheet between the cells so I am looking at .030" plexiglass to fit that part.
I bought a more accurate multimeter but it only does 2 decimal places. the second photo shows a 36mv delta while charging on the 26th of december.
Gee wiz people.
Buddy heaters are meant for camps, and various uses and do work well but NOT INDOORS with a closed up building !
Carbon Monoxide FOLKS ! They are not direct vent, as they run & burn the LPG, they emit the usual humidity that results from LPG Burning but also CO2 which you cannot smell or see but will kill you if it get's too high.
Kerosene IS nasty stinky but at least, it forces you to open a window or two to keep fresh air coming in.
BTW: LPG appliances can be converted to use BIOGAS quite easily as their jetting is almost perfect (unlike Natural Gas which is high pressure).
BioGas Generators can easily be DIY'ed or even inexpensive retail units can be purchased.
BiopGas can work in just about every climate, they even have some running 7/24/365 in the Northwest Territories ! so Cold is NOT an excuse.
Sorry, but I guess I should get rid of my gas range and dryer (hot water heater and normal furnace too?) The gas dryer probably vents outside, don't really know, I do know the hot water heater and furnace do. That said, I watched my grandmother and grandfather use a an unvented natural gas floor heater for at least 30 years for their two story house. You didn't want to stand on the metal grate when it was cranked, but it really didn't need to be cranked. Like everything in life (and invented by man), some common sense is needed. I have used my big buddy heater indoors when it was -20 outside, and it never set off the carbon monoxide detector. We should probably ask them to remove this phrase from their website? "With the Oxygen Depletion Sensor (ODS) and accidental tip-over safety shut-off, you can be sure that you will enjoy years of comfortable indoor safe heat."
Not to be a pain, but if it is -20 outside, and your power dies, don't hesitate to fire it up. Certainly beats burst pipes.
that is quite a bulge on the whiteboard. right now I am using 2 rods on each of the outsides and 2 rods down the middle so 2, 2, and 2 for a total of 6 3/8 steel rods. I am looking for a plastic pipe to put over the threaded rods to take away the abrasive threads from the blue vinyl/shrink-wrapped Lishen cells. thanks for sharing that picture. my 16 cells are wired 2p8S in a block style. 8 on each side so the flow goes down one side and back up the other side. it is a 24-volt configuration. I put red tape on the positive end and a Dymo label on top of the red tape to prevent connection mistakes.
The main positive and main negative end up on the same end of the battery bank. 272Ah x 3.2V x16cells= 13,926.4Wh capacity.
wow...eye opener
If you would have kept that from bulging, I imagine at least one vent would have blown.
No I have not. I will check into it.
I bought it from MPP Solar and it is the newer version that comes with WIFI.
But I will check to see what I have and what is available. Thanks
look here coulomb is the expert on those machines myself i have a axpert vm 3 3k 24v no firmware available bummer
All axpert inverters have the same bug doesn't matter witch type coulomb is patching the firmware manually, for 48v types
what you have is a axpert.
unpached OEM firmware can be found here
watchout what you flash NO warranty any more
@ArthurEld, how long did you make your top balancing cables? I'm still waiting for my cells but got the material to make the cables today.
Drew the cells on a paper to measure, but would like to be 100% sure before I start creating all cables.
It probably took an hour or two total. I used 8 AWG wire. Cinergi is making them with much thicker cable for high amps.
I will use 6 AWG wire, but let me clarify my question :)
How long did you make your cables, the length in inches/cm? Want my measurement double checked before I start making 28 cables.
I get it to 11.5 cm center-center when measuring on my paper sketch. I would add I guess 1 cm on top of that for some margin.
If I get that right you are making temporary cables to hook all the cells together in parallel so you can bring them all up to 3.65v Yeh?
I didn't make permanent cables for that . I stripped the insulation off some household electrical wire ,no big amperage, and wrapped a loop round first Pos terminal and put on nut. Then decided which cell next and wrapped the wire around it and did up nut . and so on selecting the highest cell first then next down and so on . If you connect them and notice a large current flow with your clamp meter then connect with a resistor first to reduce or bring up voltage. Graduslly add each cell.
When all connected and left a day or more then start charging with 3.65v power source making sure there is amperage flowing an watch it gradually reduce as the voltage rises.
