mathewhgreen
- Apr 5, 2021
- 29
Hi
This may be a stupid question but here goes…
I have a 4s LFP battery pack. 270ah of 18650 cells. I have a BMS that only balances at 35ma when the pack voltages reach 4.18 which doesn’t happen as I’m not charging then to 100%.
I top balanced the packs about a month ago and checking them this evening they are now
4.04
4.07
3.80
4.08
There aren’t any bad cells as far as I can tell - no excess heat anywhere. The pack is working fine.
obviously I want to get the packs balanced.
I installed balance leads for my charger and was wondering this…
if I connect my balance charger to the pack and plug it in to the inverter which is also connected to the pack will it be ok? Will if not blow a fuse or blow up!! ?
I was thinking of something like a feedback loop but in electrical terms.. not good!!
my thoughts were I could connect it over night to keep the packs balanced before the MPPT charge controller kicked in.
Any advice welcome!
Cheers
Mat
4.04
4.07
3.80
4.08
Any advice welcome!
Cheers
Mat
