Perhaps a new thread would be in order.Scored these at a ship auction, labeled as DC only, fot $25.00 each....continous duty 24 volt 100 amps but they are uninersal input
Real model number Skylla 24-100 universal input
comeon smooth joey.......10/2 Romex is rated 30 amps intermittent duty.....under 2 hours max....24 amps continuous dutyJust noticed the multiplus transfer switch is rated for 50 amps and it looks like 10/2 romex between the jbox and the inverters.
It should be 8 awg or the master breakers need to be swapped for 30 amp models, another fire hazzard.
I stand corrected.comeon smooth joey.......10/2 Romex is rated 30 amps intermittent duty.....under 2 hours max....24 amps continuous duty
Lets try 6/2/G Romex minimum, 55 amps intermittent duty, 44 amps continous duty at a minimum
You may have noted my venom in the past against dealer installations. Most dealers don’t know what quality work is in regards to solar, never mind electrical in general. They only know profit centers.It's clear that the people that did your electrical system don't care at all about doing quality work.
Unfortunately this includes many more people than dealers....You may have noted my venom in the past against dealer installations. Most dealers don’t know what quality work is in regards to solar, never mind electrical in general. They only know profit centers.
Im way too experienced to cut corners.....if something were to happen any lawyer would have a field day with my experience in electrical.....and I dam sure dont want someone to die becuase I cut a corner......I don't think I could ever be a professional installer. I care too much. I'm slow and methodical. I'm not sure I would ever make enough money to leave my job at McDonalds.
This is my first RV, and we looked for five months nonstop.I'm late to the game on this thread, but WOW, you will have one serious system when all is said and done.
The quote above was from someone way back on the first page. Unfortunately, that is true of the entire stinking RV industry. Crappy, shoddy, patched up, piss poor workmanship. They totally don't care. Once they get your check, the salesman disappears and the service guys are buried multiple levels deep in a never ending voice mail black hole. The whole industry should be ashamed of the product they put out.
That having been said, working on an RV is a bitch -- tight cramped small spaces to work in. Wires are strung everywhere with little or no documentation. And, if you think the install is a rat's nest of wires, you should have a look at the wires strung through the RV.
I will say that you bought really great equipment and once you have it working, you will have something to be proud of. Good Luck!!
BTW, 3 months ago, I bought a 2022 Thor Magnitude SV34. I absolutely love the F-550 diesel 4x4 chassis that it's build on. But, the shell and RV part leaves a little to be desired. Eventually, I'll get all the sawdust, loose screws, misaligned cabinets, broken drawers, and such fixed and I'll have a good rig. VW
Enjoy your rig, Barry!Bottom line, I love the rv, and every time I comment, I could live in it; the wife waves bye to me. LoL
I have never seen a Class C motorhome with a ATS....Not ever...It does not need to be automatic....nor does it need to be a switch. Every one that I have ever seen has a TT-30 power outlet wired to the generator into which the shore power cord is plugged into, cheap , easy, and fully complies with the code to separate the sources so that the generator cannot back feed to the shore power. This is what is done in 90% or more of motorhomes. This does not exclude the possibility of using a manual or automatic transfer switch.I'm still wondering who said you didn't need an ATS when you have an on-board generator?
I'm guessing you also have an inside start button for that generator. Without an ATS, you'd have to some how manually transfer power transmission to or from the generator and the other ac power sources.
I suspect the dealership didn't add that switch due to the solar install. It would have been added as part of a generator package.
Are you really going to start without an overall plan?Ok, step 1, I have six 206 amp lithium batteries to the fuse block.
I have looked and can't find a drawing of how it should be set up with separate busbars and wired from there to the one fuse or two?
Can anyone point me in the right direction for a picture of the proper way?
I assume I need to connect three batteries to a buse bar
