Hi there! I just bought a used yurt with a used solar system. The charge controller is not reading properly (the screen turns off randomly and does not give reliable information) and I think needs to be replaced. I will also need to replace the batteries before winter. I'd like the new charge controller and batteries to be compatible with the existing gear. Can you help me figure out what to buy?
Currently I have:
3 LG 335 watt 24 V panels (only 1 is connected, will be in parallel due to shading)
Trace engineering C40 charge controller
4 6V Trojan T-105 batteries wired in series for 24V
Cotek SP-1000 inverter
Cotek CX2415 battery charger
I greatly appreciate your recommendations! I'm worried about getting something that is not compatible.
Evan
Currently I have:
Evan
