misterbubbacat
- Oct 19, 2021
- 168
Hi,
Here's a pics of a well built Deye 16K Single phase version of their latest Hybrid Inverter, a distance cousin of Sol-Ark's 15K. Just one 1KW more ????
The hardware build is pretty impressive. It have two built in 200A DC circuit breaker for two sets 1 AWG battery M8 input connectors, with Max charge/discharge of 290A. Grid, Load and Gen input HEX bolts connectors supporting 2 AWG. The initial impression, this is solidly built Hybrid inverter by Deye. The 16K will support the newer generation of large 550V~600V solar panels, supporting ISC(A) of an impressive 44A across all 3 MPPT
I plan to use a Victron 100A (100A * 240V = 24 KW) Autotransformer for Load balancing and providing a Neutral for Split-Phase 120V~240V, to replace the 2 x Parallel Deye 8K Split-phase. The 16K will allow me to install larger panels and my new 8 x 300A Batteries bank providing a total 122.88 KW (300A * 51.2V * 8 Battery).
Overall, I'm very impressed with the Deye 16K. Will post more details as I start the new build process.
Here's the pick of this week's pickup of the 16K from the CSF warehouse.
The 16K is humongous, sitting on it's own pallet weighing 60KG ~ 132 LBS
16K in it's new home, the garage ?
Initial unboxing ...
New wall mount bracket.
Deye branded, not brown box OEM ?
Continue on next post .... limit 10 pics per msg ?
