Today's Daly SmartBMS Android App Update forces a firmware update which fails
Did someone use not an original USB-UART converter for BMS connection? How do you connect pins?
I said...f- it I'll try them all ... all gave a version error, so that was a good check....end then....DalyBmsApp_103_303(12_221130_100T)基版本.s19 started for me...slowly...file is from @Raivan, up here
.....waiting....praying....hoping
  • DalyBmsApp_103_303(12_221130_100T)基版本.rar
Please, if you have managed to successfully reflash your BMS, could you specify the BMS model and firmware version.
I think it will be useful for others with the same update problem.
Thank you.
Ok, so I managed with the PC-master BMSmonitor v2.1.9 to upload and roll back to a working BMS, which was ruined as you can see in my previous posts>
The firmware here is linked and came from @Raivan the hardware I have is in one of the screenshots, its not a Daly, but they are 100% the same rebrands...DeliGreenCS
I tested my bluetooth with the app 2.4.0 and all is running like it was(even better!)....now hopefully the Chinese guy wants to cancel my order....already ordered another one...:cautious:
It still asks to upgrade the firmware :mad: why they don't have an emergency update for the app I have no idea!
Don't trust all the files here...I just got them also just from here...so you never know !!! Again @Raivan thanks allot !!!!!
  • DalyBmsMonitorV9.rar
Hat jemand Firmware für ein 8s 100A?
Es wäre nett, wenn das jemand nach erfolgreicher Installation hier reinstellen könnte.
Lol i was about to do it but contacted the seller and got the correct firmware file best contact the seller and get the firmware file and after that its just 5 mins to fix the issue
The files here may not work corrextly as there are multiple versions of hardware and software. Best contact seller and get firmware file.
That is just it... Even with the firmware from the seller, and following the correct instructions, I cannot get the BMS to work?
Ich vermute, dass es etwas mit dem Zeitpunkt des Abrisses zu tun hat.
Ich habe das Update kurz nach der Veröffentlichung manuell ausgeführt, in der Hoffnung, dass es mein BMS-Problem mit falscher Strommessung und -anzeige lösen würde.
Zuerst funktionierte der Firmware-Code 123456 dreimal hintereinander, aber mit einem Abbruch nach mehr als 50%.
Danach wurde der Zugriff über 123456 gesperrt.
Meine Vermutung: Der Fehler wurde in China entdeckt und der schnellste Weg, das Chaos abzuwenden, war, den Zugang über den Code zu sperren!
Die Frage ist, wann der Download-Stream abgebrochen wurde......
Die Code 123456 ist nicht gesperrt, die Firmware im BMS ist nach fehlerhaftem Download abgeschossen. Bei zweitem Versuch erkennt Smart BMS Apps die Hardware nicht, und bietet kein Download (und 123456 Code) mehr.
Nach Absturz meldet sich BMS (Apps) mit 20200429-1.01T FW und funktioniert nicht, ist aber noch ansprechbar (UART).
Mit UART/USB Adapter, PC Master (V2.1.9) und passenden Firmware kann man den BMS retten. Mindestens bei mir war es so.
Die Einstellung Daten sind im Gerät erhalten (Parameter).
Nur Passende Firmware flashen (es gibt verschiedene HW Variante von Daly BMS).
Die Code 123456 ist nicht gesperrt, die Firmware im BMS ist nach fehlerhaftem Download abgeschossen. Bei zweitem Versuch erkennt Smart BMS Apps die Hardware nicht, und bietet keinen Download (und 123456 Code) mehr.
Mit UART/USB Adapter, PC Master (V2.1.9) und passender Firmware kann man den BMS retten. Mindestens bei mir war es so.
Die Einstellungsdaten sind im Gerät erhalten (Parameter).
Nur passende Firmware flashen (es gibt verschiedene HW Variante von Daly BMS).
Ich verstehe. Wie gesagt, es war meine Vermutung. Trotzdem tue ich mich schwer, welches ist meine richtige Firmware-Datei für meinen 8s 100A???? Hilfe???? Zufälligerweise wurde das UART-Kabel vor einer Woche mit einem Ersatz-BMS bestellt. Bedeutet, dass ich erst Mitte Januar einspielen kann!
Mein aktuelles BMS ist privat gekauft und Daly rückt natürlich nichts raus !
Frage deinen Verkäufer, bei mir waren die sehr hilfsbereit (Ali). Eingenlicht die sind für das ganze Mist verantwortlich.
Oder lese Post #5 im:
Da schreibt ein User, dass die 100A und 150A Version - BMS-GD230-309E HW hat.
Das was ich weißt, die S-Zahl ist ohne Bedeutung (6S, 16S).
Mein Daly 80A 8S 24V LiFePo4 auch GD230-309E HW hat. Die Firmware liegt hier im Forum.
Frage deinen Verkäufer, bei mir waren die sehr hilfsbereit (Ali). Eingenlicht sterben sind für das ganze Nebel verantwortlich.
Mein Daly 80A 8S 24V LiFePo4 hat auch GD230-309E HW. Die Firmware liegt hier im Forum.
PRIVAT gekauft ! Leider kein Verkäufer.
Die S-Zahl ist tatsächlich ohne Bedeutung, habe ich schon erfahren.
Ich hatte ähnliches schon gelesen, war nur nicht sicher.
Jetzt ist es klar! Danke
Had same issue. Used secondary android device. Made sure play store was set to not auto update apps, went to APKPure and downloaded the 2.2.5 older version of Smart BMS app, and side loaded it. It gave me back the control of both of my Daly BMS's and no longer prompting for upgrade. May not be the answer but maybe a workaround for some.
This worked for me, thank you for mentioning the website name and the version number. I've since Uninstalled all previous Smart BMS data, downloaded and installed 2.2.5 and I've got all my functionality back. You are a life saver
Is it worth the risk to try on a 4s 200a one?
I do not get respons at all from where I get it from...
hi try the firmware on the link of this YouTube version , there is no risk as if its wrong version it will simply return a version mismatch error
Ok, I've just asked the official site from taobao(https://daly.tmall.com/shop/view_sh...3998/evo318828b447259.202202.1.7a577dd6sSFa8w) regarding this issue. The conversation is as the follows:
The simple translation is as the follows:
I: Why is the apps not functioning, I can neither upgrade software nor operate normally.
Daly Customer Service: Do not click upgrade, the software is under testing.
I: Ok, understand, thank you.
Daly Customer Service: Please use the original(old) version (APP).
It's seems that we need to give them sometime to complete this software test. Everyone please be patient.
Very strange, because I had disconnect issues with bluetooth app v.2.2.5 during night time (and sometimes draining my battery down) and now with version v.2.2.8 version (auto-updated on my phone) everything works like a charm..... I have a 4S 100A BMS.
Edit: Oh, I haven't seen that there is a new v.2.4.0 version on Google PlayStore. Thank God I have it on manual update!
Installind the 2.0 app it works for the moment..I thought it bricked the bms..
