Today's Daly SmartBMS Android App Update forces a firmware update which fails
Salut la aceste bms avem șanse sa le facem ceva dacă sunt blocate sau va scoate cineva vreun soft să ne ajute ...nu merge nici ,,123456,, va multumesc pt orice detaliu
Mine: Version 2.4.0 funktioniert immer noch einwandfrei.
Drücken Sie nicht das "Software-Upgrade"
Bis zum firmwareUpdate war das bei mir auch so. Aber mit falschen Zellenspannungen und 2 Thermofühlern, obwohl nur einer vorhanden .
Die Taste für Aufzeichnungen führte zum Absturz.
Da hätte ich kein Vertrauen.
Daly Support sent me this: "Try the code 322701". For me it doesn't work ?
I solved the problem!
I have 2 Daly lifepo4 8s 100 amp and 1 Daly lifepo4 12s 100 amp BMS, I just ordered 3 JBD 6-22S 100 amp BMS and wil trow all 3 Daly BMS in the garbage when the JBD's come in!
I've had it with this Daly crap!
Könntest du die Firmware irgendwo zum Download stellen? (als Dateieinanhang)
Ich korrigiere: Heute Nacht (chinesische Zeit) wurde auf meine Anfrage geantwortet ! Ungewohnt per whatsapp wurde kommuniziert und ich bekam ebenso per whatsapp die Firmware passend zu meinem BMS ! Danke Selina !
Falls möglich bitte die Firmware für das 8s 100A BMS hochladen. Danke :)
Hi, I also got a new firmware but only important for the new parallel BMS systems I attached everything so that you don't do anything wrong.
  • DalyBmsApp_103_309(11_221122_001T)+¨¦µ¦¥.rar
I just updated the app via playstore (it shows that the new version is from today) and it works for me. It doesn't force me to update it and I can access everything. btw does anybody know what does the data reporting with that warning sign mean? It asks me for email but nothing came to it.Screenshot_2022-12-29-15-17-26-107_com.inuker.bluetooth.daliy.jpg
v.2.4.3 works just fine! Lots of new options.....translation of the 1st button says "heating switch" ....heating of what???
2.4.3 doesn't work for me. Still frozen App. Maybe only option is to flash new firmware via uart-usb cable?
Someone got correct firmware for 24V 8S 100A BMS?
