ghostwriter66
"Here - Hold my Beer"
Sounds like a hardware issue. The new firmware is solid. I think something on the unit is defective.
I'm sure it could be a hardware problem.
You are a trusted person in this industry, possibly the most trusted in the DIY space, and have a solid working unit with a firmware you like in your possession. Theoretically however, nothing you could do with this defective unit, Signature Solar couldn't do better at their shop.
It's a matter of impartiality though. Whom do we here on the forum, as a whole, find more trustworthy, Will Prowse, or Signature Solar? Judging from past threads, I'm going to say.. Will Prowse.
Regardless, it will be interesting to see what the verdict is. Peak shaving is obviously a very important feature given the increase of time of use billing we can expect to see in the future.
I will say that its NOT a hardware problem but a software/firmware causing the hardware not to do what it needs to do ... Watts Happening clearly stated that at one point the other tech had it working just the way that it was suppose to when it came to not feeding back -- and then when Tech #3 came on and updated the firmware then the issues came back .. so not hardware but software ....
People saying things are rock solid is fine as long as they say what the parameters are that they have tested the equipment with ... obviously WATTS Happening tried to have it do something that it should have been able to do -- but simply did not have the proper software wrote to do it and odds are - will never have the proper software to do it ...
remember - and I say this as a Chinese-American - but for anyone that has had to deal directly with these manufacturers -- the Chinese phrase of "Well its does what its designed to do" is one of the first phrases you learn to listen for ... the problem is that the manufacturers design it for one thing - and then the creative marketing team adds a few things here on the marketing page ... and it becomes a slippery slope ...
Look at all the wind turbine that weigh 5 pounds but supposingly can produce 10,000W - aaaghhh
Or these little $10 SCC that supposingly can do 40A - aaaghhh
a year ago we were all buying crap batteries dressed up in lipstick and bows all hoping that we get lucky and not get the REALLY bad ones ...
and the list goes on
