Beetle Bailey
I'll tell you from experience, listen to this man. I had the same issue a week ago.Searched and tried to read manually through this giant thread but didn't have any luck. I just got the 18k today to replace 2x6500. Moved all the wiring over and couldn't get the batteries to communicate (4xEG4). Found the thread on needing to upgrade the firmware on those. Changed the battery type to lead acid as per the manual to get things going.
The real issue is that the batteries are fully charged but none of the solar is being used for the house loads. Using it with the critical loads panel and have not installed the CTs. No grid export. I must be missing the option to have it actually use the solar/batteries for loads! I did test it with just the batteries before turning on the grid input and it could power things and I saw the correct voltage between the legs.
If you want to follow the questions I posted and go from there it starts at #934. Exact same issue.
