eXodus
Solar Addict
- Jul 27, 2020
- 1,483
instead of water tank you could just have flat plate where you can stack cinder blocks on both sides.I was originally thinking of a bouncy horse when I thought of it.. perhaps just weighted down with cinder blocks or a ballast tub full of rocks instead of actually in the ground. If it could be kept pretty small diameter, since it sways with the wind instead of outright fighting it, maybe a regular handheld auger and a bag of concrete or two could do it per panel.. or some of those anchor screws.
concrete blocks are 8x16x4 and about 33lbs heavy
A solar Panel is 40 wide, if you have a grid 40/8 inch you could have 5 bricks on each side - so a total 10 concrete bricks for one panel. Cost about $2 each Roughly 330lbs total.
So the ballast would be about $20 bucks, If that's not enough heavy you can stack another layer. $40
Two rails on both sides, $30-50
two springs ??
And few L-metal pieces to where the blocks sit in. Plus welding....
Yeah we are getting in price territory where it doesn't make sense anymore. You can't spend more then $50-100 for installing one panel.
Would be fun, but not economical.
Just ramming metal sing posts in the ground - You can do a lot faster and is something road sign contractors and fence builders do all day
