Rabbit
- Nov 19, 2019
- 85
Most budget LiFePO4 100ah batteries are only equipped with BMS's rated for a 100 amp sustained discharge, which is inadequate to power a 2000 watt inverter especially at low charge levels. I'm well aware that in practice you can pull a lot more than 100 amps from most of these batteries for a surprisingly long time, but... I like to do things right whenever possible. I'm considering buying one of the new Licitti 2000 watt AC battery boxes, which is equipped with a 2000 watt inverter in an enclosed configuration where there appears to be exactly enough room for only one 100ah standard size battery. Does anyone know of a suitable LiFePO4 battery that's both dimensionally standard and can put out, say, 175 or so amps sustained for a reasonable price? Or must I cobble up my own? Thanks!
