I put this system in June 2019, my first. We have great grid tie laws in Arkansas. Full credit for any excess that goes onto the grid. I get $$ credit on my account monthly with monthly energy cost adjustment. This credit pays for my monthly service access fee and a bit more. I oversized, planning to retire in a few years and expect to be using more power once I am at home all of the time. The mount is fixed angle. The substructure, I made from steel drill pipe and then used Iron Ridge mounting rails and hardware. I have 8, 4 port APSystems QS1 microinverters, peak total rating 9.6Kw. From the house is a 240v 50 amp circuit coming from my main panel, with outside disconnect. At the array field I have a post with breaker box and local 120v and 240v outlets. All normal 240v AC wiring ran right to the grid tie inverters without any "solar" gear in the system until I connect 240v to the microinverters. I have 32 older designed (but never used) SunPower P17-340 panels. On a cool sunny day I can hit 10Kw at midday. I am making about 1500 KWhr per month average.
Sorry little tree, but you will have to go.
Local 240v circuit runs to the inverters under construction.
