Am testing my batteries to see how evenly the load goes out between them. The higher the load, the closer the margin.
During a 1580 watt load, the batteries were within 2.8% of each other. Right now, I say that’s a success.
Wanted to know how even the BMS ran during a load so I Monitored how much both BMSs put out running the microwave At 1580 Watts total:
BMS 1: 780 Watts (29.27 Amps / 26.69 Volts)
BMS 2: 801 Watts (30.02 amps / 26.68 Volts)
During a smaller 265 watt load, They were within 7.9% of each other.
BMS 1: 175 Watt (6.51 Amps / 26.88 Volts)
BMS 2: 190 Watt (7.05 Amps / 26.93 Volts)
This is not scientific, so although BMS 1 consistently put out slightly less, I can’t say how accurate the Overkills are in measuring volts and amps. These measurements also fluctuate slightly, so I pull a number that is close to the average. I did take great care when making these cables to make each set of wires paralleling the batteries the same length, and scrubbed and cleaned with alcohol the lugs and busbars.
