rrleesb
I'm building a 12v 4 cell 280ah battery. I got the cells and BMS from Jenny Wu.
I have it all wired up but the BMS doesn't seem to be operating correctly(or at all). It's a JK-B2A8S20P. I've followed the wiring instructions but I can't connect to bluetooth and it isn't taking/giving current. I have the black wire to battery neg, then sense lead one to the same battery pos, and on down the line with the sense cables on the positive terminals. B- goes to battery neg and P- goes to the output side of the BMS.
It came with a small pushbutton that plugs into the display connector, but having it attached doesn't seem to make a difference and the manual says it does not come with any on/off switch.
I only have the one wire hooked up for testing.
Any ideas where to start?
