Testing was not done in the summer--but you're right. But I also do not need much negative (venturi) pressure across the SS pipe end. And the hot pipe is insulated and will be less than about 9 feet long and most of the inside...seeing as how I'm using cold air for the driving effect of venturi I then need the necking down diameters (increasing velocity and decreasing pressure) go across the stainless steel (SS) exhaust pipe end drafting out the hot SS 'air'...it then dumps to the atmosphere about 12 inches further...so no hot heat issues should be involved with any of the connections or fan or electrical all being separated from heat. If you look up "extractor cones" "eductor pump, eductor venturi, eductor nozzle, eductor tee" then you'll probably learn a new word as I have never heard the term EDUCTOR (and yes that is spelled correctly!)Be mindful drafts are dramatically impacted by exhaust temps. By injecting cold dense air to a weak draft, it may counter any Venturi effect.
Testing in the summer of a doesn’t reflect when temps are in the teens.
YUP!!!Now THAT makes sense! Fan at the Motive and Discharge points? Smoke comes up from the Suction end?
The FAN is mounted at the MOTIVE end and blow through to the DICHARGE end and across the SUCTION Tee lifting the exhaust gases from the SUCTION end and blowing them out the DISCHARGE so the fan NEVER gets hot nor the bearing cookedNow THAT makes sense! Fan at the Motive and Discharge points? Smoke comes up from the Suction end? I don't think the fan at the Discharge point is really buying you anything other than smoke in the fan bearings.
Aaaah, I did not think to measure amperage (that's a dumb on my part... Duhhhh!) what I did was to estimate the setting on the rheostat to max CFM and half and other knob angles on the rheostat as divisions of less than max CFM. It is correct isn't it, that if a fan pulls 6 amps at 270 CFM then at half that knob setting (from full) then at 135 CFM the amperage would be about 3 amps? Am I off on that 'logic'?! I have both options for the Styrofoam and naturally for the angle iron and mounting. If I get 24 volt solar panels and then a battery to take that then using only the 12 volts doesn't that give me twice for using the 24 volt battery and solar panels...I just have to select my voltage controller to 12 rather than 24 (don't want to blow up the fans!). I'm not too restraint for funds ($$) so if you think of an arrangement (and with your helpful links) then I'll certainly go check it all out. I suppose Will Prowers has some systems?!So what did you find was the lowest setting for the fans amperage wise?
Solar panels are designed to be out in the weather, I wouldn't worry about keeping them dry as long as your connections are waterproof you should be fine.
Your notes say you've got about 6a of fan draw which is a LOT if you can't slow them down quite a bit. Just some napkin math using the Wally World 120Ah Deep Cycle batteries that gives you about 10 hours of run time per battery and you'll need at least a 100w panel AND 3+ hours of really good sun to top them off in a day. 200w would be better and it's easy to do.
Is that Styrofoam container one of the cheap white ones or is it an actual cooler? If it's a cooler then pick up a roll of rubber weather strip for the lid and that should solve your weatherproofing issues just fine. If it's the cheapie white ones, craigslist for a cooler with a hinged lid.
Some simple angle iron with holes and a couple bolts can make legs to help push the bottom of the panels away from the railing so you can get a good angle to the sun. Straight up and down isn't going to do you much good, you'll take a pretty significant production hit.
Sounds like you're coming along nicely!
Hi, Circus... I have not seen such a kerosene heater as you have supplied a picture of (do you have a link?). I do have a Dyna-Glo 23,000BTU... It's a big white cylinder looking thing and it holds 1.9 gallons of K-1 Klean Heat kerosene (and I have some of it stored!). Instructions state it will burn for two hours. I fired it up in my friends barn and it did OK but it does smell and it does need make-up air (which I have for the woodstove so that's a moot point). The thing that concerns me is the storage of the fuel. If I spill it and it soaks up into the carpet then I'm screwed...it does not evaporate enough that I could get it out of the condo unit...and seeing as how it is more flammable when in a medium of a wicking material--such as the carpet ...I'd really be pushing the envelope on fire danger. I realize that the wick in any such stove needs to be adjusted to burn cleanly (that is, adjusting the wick height is not done to regulate the amount of heat but only to make for more complete burning of the fuel and less combustion agents inside the living area). getting back to spill mistakes: I would have to rip up the carpet and toss it out...as the danger would be too high otherwise, also pouring the fluid is a real difficult task (I have it in mind that I put the unit in a big aluminum pan used for collecting water spill from a water heater and then if I miss pour the fluid it will end up in the aluminum pan for me to sop up with paper towels). I also have a Mr. Buddy Heater (Propane) and have tested that in my friends barn...that also works fair and storage of the little 1lb bottles (in my mind) is safer than the K-1 mainly because I have wrapped each propane bottle in its own zip-lock bag and then stored them in a large cooler like container with a sealed-lid. All the product is in my bedroom (meaning if there is a leak I will smell it...and besides everyone of them would need to 'pop' to gas me out of air while I sleep...and that's too far fetched to happen). And I do not heat my bedroom with the electric baseboard heater...ever. so there is no flammability issue there. I guess you're about to say I should move out of the condo and get a house with a barn and become more like the Canadian Prepper (seen on youtube) ha ha ha, and I would but for I'm now too old to take care of such a building and also I'm prior military and do not have the funds.... Thanks for your response though...Far be it I discourage inventiveness but all your problems would be solved with a $120 kerosene heater. Easily heats 800 sq ft 14 hours on a gallon of kerosene. When tuned has no smell. No electricity. There's awful wood burning boilers that spew out cold smoke that hangs low to the ground. Always downwind of the home owner but gasses the neighbors. When I bike pass my eyes sting.
Right on... Rednecktek!! As my ICON indicates... I'm a geek with my fingers in my ears waiting for (now, not the explosion but rather) the implosion of the country ha ha haOK, a couple thoughts:
There's no such thing as a "12v panel" or a "24v panel", it's just a marketing term to represent "Would create enough voltage to charge a 12v battery" or "charge a 24v battery" so don't worry about that. The big thing you're going to want to pay attention to is the VoC rating for each panel.
The sun angle is based on latitude, and the PVWatts can give you the best angle for each month because the sun isn't as high in the sky in winter as it is in summer. As a rule of thumb latitude = angle for general all 'round performance. You'll want the sun perpendicular to the panels as much as possible for optimum performance.
As for what to get, 100w panels are a handy size to move around but are the highest cost per watt. If you can swing it, you might want to look at a 400w panel or so that will fit on the porch, or a way to hang a couple 200w panels, or 4 of the 100w panels. It all comes down to what you can physically fit over the rail. Since you're running a 12v system, 800w (12v * 60a = 720w) is pretty much the maximum you can utilize. Usually 1x 400w panel is physically smaller than 4x 100w panels, so tape measure time!
You'll want your panels, a nice (Victron, EPEver, etc) 60a MPPT controller, the batteries, fuses, and a shunt monitor. The MPPT controller will let you utilize the panels more efficiently for more power through the day and in lower light situations like cloudy days. Since you're running this all off of 12v there's no need for an inverter, it sounds like everything you need is either 12v or USB and there are LOTS of USB options out there. The shunt monitor (the Ail's are a popular choice) will tell you things like how much battery you have left, how much you're drawing, how much you're charging, etc. The display is connected via a small cable so you could mount the monitor right in the side of the cooler so you can see it at a glance, or run it to your "control board" by the fire that has the rheostats. Wire can go pretty much anywhere.
Your amperage guessing is about right for paper, but power is a bit logarithmic so if your 6a draw is about half-way on the dial, you're probably closer to 2.5a than 3a. That's where the shunt display comes in handy too.
@circus: Yeah, ideas like that have been covered but fuel storage is an issue and he's trying to "Make a project work" as much for fun as functionality.
Nice reply, Rednecktek. Lots for me to think about...and I admit I'm not solar savvy but very solar curious. With all you mentioned I have also been looking at Will Prowers you tube videos (I believe he is really into all the solar stuff... and that's an understatement! ? ). I was wondering if you have looked over any of his videos and if there is one there that he has done that sort-ta parallels the vision I have of a solar powered duct fan for my wood stove? I could just get a kit of sorts and get on with it...but I also wanna play a bit (my friend with the barn is also interested and is watching me...ha ha ha and perhaps hoping I stick my finger in some shocking solar 'hole'). So I'm going to be in the basics of understanding what to do and get and hook up (set-up) and I figure I can toss about $3000+ into this...and realize that the battery needs to be a Marine deep-cycle LiFePos type (which is fine) and for the panels I can afford the 400w or two 200w. I am also not going to be pushed to make all this buy the time the winter can get me into a power-outage dilemma--I'm just going to move forward slowly and get it done when it all comes together. Seeing as all this is only for emergencies hopefully I will never need it...but that's not true for my friend he wants me to drag it all down to his barn in the dead of winter and test it all out--which I hope to do! Thanks for all your help and your continued help will be appreciated. You're going to get kudos to this board when I can figure that out...as you know I'm new to the board too!!Right on... Rednecktek!! As my ICON indicates... I'm a geek with my fingers in my ears waiting for (now, not the explosion but rather) the implosion of the country ha ha ha
Yea, I have one rusting in storage. The radiant style is better. Smaller. Fuel tank comes out for refueling. 18 hours per fill. Fuel level, the wick is in, doesn't change as the fuel is consumed making periodic adjustment unnecessary. Of course lighting, extinguishing and refueling would be done outside on the small balcony. I don't own the model shown but my 30 year old heater is similar.I do have a Dyna-Glo 23,000BTU..
