Few points... btdt many many times... I suggest avoiding jumping to conclusions based on assumptions, it rarely works out that way.
1) Check all busbars for ridges & burs around the holes, file them OFF so they are smooth and make full contact.
2) Clean ALL Contact points to remove oils/greases & waxes (yes everything get's a coating of one or the other) this is normal. Cutting oil, waxes to protect the raw aluminium etc. (you would be shocked to know how much that can affect readings).
3) Check all your BMS Leads from ring-terminals to connector to ensure they are all GOOD !
* NOTE * Always disconnect BMS when Futsing with wires, easiest way to fry a BMS.
An overly aggressive Charge Profile will also trigger a RUNNER cell and result in what you are seeing, having one cell go up or down faster than its companions. Nominal Voltage is 3.200, Working Voltage Curve is 3.000-3.400 Volts per cell. Anything above 3.500 or below 2.875 are cliff edge and represent <5% of capacity. Charge cells to 3.650 till they take 0A, within one hour of charge stop they will settle to 3.550 +/- and two hours to 1.490+/- which is NORMAL.
Here is my 24V Charge profile for a Midnite Classic 200 SCC, try to match your SCC Charge profile and you will not have runner issues and the batteries will top up and level out quite nicely.
All equipment MUST BE Voltage Corrected & Calibrated (VERY IMPORTANT) see link in my signature on how to do it.
Divide Values X2 for 12V. Multiply X2 for 48V.
Absorb: 28.2 for 15 minutes (3.525vpc) (some call this boost)
Equalize: OFF
Float 27.9V (3.4875vpc)
MIn Volts: 22.0 (2.750vpc)
Max Volts: 28.7 (3.5875vpc)
Rebulk Voltage: 27.7 (3.4625vpc)
End Amps: 14A (*1)
(*1): End Amps is calculated from the Highest AH Battery Pack in a Bank. IE: 200AH X 0.05 = 10A 280AH X 0.05 = 14A.
NB: Victron Forum discussion says EndAmps = TailCurrent
This get's the bank charged to full with high amps (Constant Current) and then float (Constant Voltage) tops off so the cells are on average between 3.475-3.500. I am running 7/24/365 so float is used up by the Inverter + provides whatever the packs will take to top off.
** Coulumbic Efficiency for LFP is 99%
