sunrise
- Jul 16, 2020
- 206
A lot of consideration went into the strength of the case, it's actually supported by 4 3/8 rods. so absolute you will be able to lift it.Looks nice. THere’s been so many things over the last year and a half that a 3D printer would be handy. I went with a Battery vent hose that printing up parts would have saved days. THere’s plenty of others.
Keep in mind I know nothing about 3D printing.
Is that case stout enough to lift it? If so that‘s awesome.
Thank you, I will be using PLA or PLA+That's an elegant design, the way the different pieces are modeled looks like it will print nicely. PLA or ABS or what type of filament you going to use?
Thanks!Looks very nice!
Did you consider ways in which you could minimize the opportunities for a short between the battery posts, it looks like the battery posts (as well as the BMS heatsink) are all pretty exposed and close together with no separation.
Hi @bryn, thanks! I use Fusion 360 for the design. it's free for non-commerical use.Damm Sunrise, that is a nice looking case, I'm looking forwards to seeing how it turns out, as i've got the same cells and BMS
Can i ask what program you used to design this, i'm going to have to learn how to 3D print
I'd tempted to add an extra level above the heat sink and incorporate some fans activated by the heat port connection on the BMS as i live in a hot climate
Definitely would consider a vented top. I already designed a 3mm clearance between heatsink and top cover opening for this purpose.Not sure if you wanted the heat sink removable from the top without opening ththe case, but I think the model is super clean. Might be able to add a vented top that covers the heatsinks on the same print as the top. Not sure how hot you think the heatsinks will get, but could use some close tolerance, though heat is the only prob with pla. I've left pieces I've printed in a hot car and basically had them deform a bit.
I do like abs for its thermal properties but PLA is tough stuff, strong, and hard.
Cant wait to see the prints!
Thanks that is good to know, as i'll be running 2 x 12 volt packs in my camper, and heat is a concern with more draw.Hi @bryn, thanks! I use Fusion 360 for the design. it's free for non-commerical use.
A couple of weeks ago temporarily put the cells and BMS together in my travel trailer, and ran 13500BTU A/C (in heat pump mode) for 30 min or so, It draws about 1400w, for about 5 minutes I also turned on a 400w dehumidifier. I didn't feel BMS even got warm when I touched it. But the environment temp was ~40F.
One of the reason I choose this BMS was passive cooling. So I won't be putting a fan as I don't think it's necessary.
For functional parts, I use 15-20% honeycomb almost exclusively. it offers far better strength than the default one.What infill are you using? PLA can be strong with relatively low (20%) infill, but depending on outside wall thickness sometimes 100% infill is a small price to pay in more filament while not adding much time to the print.
The mounting option is where this design truly shines, with a bit longer rod at the bottom, I could add a printed clamp at the end, even hold down 2 batteries side by side. or if I am length constrained, I can put a tab with screw hole on the side, the possibility is endlessThanks that is good to know, as i'll be running 2 x 12 volt packs in my camper, and heat is a concern with more draw.
I also choose this BMS, due to the large heatsink, the 200amp Daly BMS on my 240ah pack use to get quite warm, but ill be splitting the load with this pack, so i'm properly overthinking the heat issue.
I might have to download 360 Fusion and play around, i need something to tie the case down, such as an extended tab at the bottom
How many pounds/Kg of filament do you think will be needed?
@bryn I was waiting for copper bar and 1 awg wire to arrive for fitting verification. I will start the printing tomorrow, and I would take a few days to complete. Definitely will post update here, no matter the result is.Just posting to bump this thread as i'm interested to see how it turns out
