Not sure your knowledge level will try to cover it in one post. Feel fre to ask questions I am no guru with solar and these lifepo are new to me.I purchased 4 of these batteries last week- expect to receive them on Tuesday. Seeing that they replaced one for you so quickly is really nice to see. I am using these to replace the sealed lead acid in my Ryobi zero turn lawn mower. They were basically the same price as the SLA. My concern now finding a 48 volt charger for them.
This is what I bought - in the picture no longer available sold out. It supposedly puts out 48volts at 13 amps. It will be my back up charger for my 48 volt battery set. My primary charger will be the MPP 3048 all in one solar inverter system. Some ppl call them AIO. Several versions available. Most ppl are real helpful and knowledgable here.
You could get an all in one inverter then have your lawn mower setup as an emergency back up power supply too. Your lawn mower and or EV could serve dual purpose. In bad times you most likely won't need to worry about mowing your grass. From what understand this battery bms restricts charging to a max of 50 amps. An all in one inverter might be a good choice you will have to setup a resistor to charge the - inverter system every time connect. Get a couple of solar panel and you are off to the races. Most ppl only think of ev as charging them to drive. They - EV are also huge rolling battery storage. I'm really not sure why ppl don't look at EV and such as a rolling power supply.
You might be able to get an mppt and solar panels to recharge.... if you don't want or need an inverter. Most good mppt are expensive. And again the battery if read it right is limited to 50amp charge.
This MPPT would require throttling back on charging current to 50 amp or less. Setting solar panels up no more the 150 v open circuit.
Or just look for a dedicated lifepo 48 volt charger 120 volt ac charger .... the lower amps like mine means it is going to take longer to recharge.
Nominal 48v x charger 13a = 624watts
Nominal 48 volt battery set x100amp = 4800 watts so you can see it will take a while.at around 4800w / 624w = ~ 7.7 hours.to charge using nominal.
Given the battery info statement of 1280watts per battery means 1280w x4=5120 watts so
5120w/100a = 51.2 volts.
51.2volts x my charger 13a = 665w
5120w / 665w =~7.7 hours with my charger.
Check my math using ohms law. But basically with my charger you at 120vac and 13 amp will take around 7.5 plus hours.
Be aware this is nominal voltages.in one vs. the charge voltages will be much higher..... as will the watts output and that is why showed them. 48 volt batteries usually reported as needing around 57 volts to charge. Recommended charge voltages are 14.2-14.6 volts per battery ..... with these. Picture chart included per Himassi.
If you go with mppt solar charger just don't hit it with over 50 amps charge as built in bms will most likely shut you down. Again it is set at 50amps per battery with these. Personally high charging rates make me nervous.
Look around the forums and ask questions.
