Observations
Setup 4 new Himassi LIFEPO smart bluetooth 12v100ah batteries and testing - simple observations.
4 new LIFEPO smart bluetooth batteries charged individually.... show and maintain 100%after charge but within a 2 day period the 100% creeps down to 99% per individual battery. 2 days.
So take all 4 LIFEPO smart batteries 12v 100ah and charge to 100% again. Tie them parallel all positive to positive and all negatives to negatives with zero - no external load preparing for a follow up series tie.
Next day 24 hours later parallel batteries are all at 99%. So at this connected drain rate the batteries will most likely be dead in 100 days at 1% self discharge each day -24hour period.
The smart feature will have drained them down to 0% or to whatever the bms is programmed to shut itself down stopping that drain. Whatever. Again No EXTERNAL loads are on the parallel 4 smart batteries and this is just all internal load. 1 day 1% drop ~13.3 volts each battery as bluetooth reported.
What is the advantage of smart bluetooth batteries besides the builtin smart bluetooth feature draining the batteries. Again the Parasitic loads are built into these batteries. An Inverter will add more parasitic draw at idle so more items using load - power will increase additional loss.
Example My refrigerator not doing anything - pulls 2.5 watts... suspect it is just running the defrost timer.
What is the 100% SOC and Drain Rate for charged Lead acid batteries if no load In 24 hours or 100 days for a percentage?
What is the 100% SOC and Drain Rate for Silicate Salt Batteries if fully charged no load in 24 hours or 100 days for a percentage?
Are LIFEPO smart bluetooth batteries really worth it?
How much does a normal bms without bluetooth pull in a LIFEPO 12v 100ah battery in 24 hours or 100 days?
How much does a 48volt EG4 "type server rack battery" pull itself each 24 hours or 100 days no load? As understand it the 48 volt eg4 has only have 1 bms.
Seems there is an advantage to buy 48volt Server Rack type batteries such as: sok eg4 and others vs individual smart bluetooth to run in series. Less bms
Ppl seem to always talk about inverter idle state loss and waste but what about bms waste....I will say the Bluetooth allowed me to see this reported loss of 1% a day..... but dead batteries from a complete shutdown system in 100 days is not good either.
What to do. Silicate salt batteries are heavy but... have not seen much info on them for no load shutdown = drains. You can crank a car with silicate batteries. Hmmmm 20% dod.
BTW the code password into the Himassi smart bms app is 666666 but it is monitor only Had to search the web for it. Also read on a website that the internal heaters will not let the bms battery charge function until temp reaches 50 degrees f with the internal applied heat. Hmmmm
