CamboMoods
- Nov 6, 2020
- 2
Hi all,
I am looking to create a battery bank using the following batteries:
VoltaX 12V 100Ah LifePO4 Lithium Batteries
I am wanting to create 2 banks of 400AH at 48V (I have 8 of them) and am wondering what would be the best way to cable them?
Also, do I need an additional BMS? the place I bought them from states they have them built-in and that I can have up to 4 in Series and unlimited in parallel
here are the battery specs from the seller's website:
SPECIFICATIONS
VoltaX 12v 100Ah | |
Nominal Voltage | 12.8V |
Nominal Capacity | 100Ah |
Usable Capacity | 100Ah |
Energy | 1280Wh |
Charge time | 2-4 hours |
Weight | Approx. 9.5kg |
Charge Voltage | 14.6V |
Discharge Cut-off Voltage | 10V |
Standard Charge Current | 20A |
Max. Charging Current | 50A |
Max. Continuous Discharge Current | 50A/0.5C Rating |
Max. Discharge Current 5 Seconds | 125A/1.25C Rating |
Cycle Life | 2000 times |
Internal Impedance | ≤50mmΩ |
Dimensions | L 330.3 x W 173.4 x H 215.6mm |
Working Temperature Range Charge | -20C--60C |
Storage Temperature | -10C--50C |
