Do you remember what video that was in?
I would wait until SRNE releases the 10Kw version that can be put in parallel. It should be released soon. If you plan on expansion or need the inverter capacity, that may require parallel units.I am considering getting this inverter, what is the max amp output listed on your solar panels? The panels Im looking at are about 13.5 amps each and I would like to parallel them but since the max draw is 22 amps I would lose a fair bit in ideal conditions. I also wonder if over paneling it would reduce the lifespan, my idea was 6840 watts per mppt input. You mentioned adding more inverters, Im curious how you do this without paralleling them? I dont really undertand how I could expand on this system other than running seperate electrical panels for each AIO. Makes me wonder if I should get a couple 6000xp instead for ease of expansion but the cost would be practically double.
You can use the SRNE 5kw versions, those can be in parallel.ya i realise I wouldnt be able to parralel with a 6000xp for sure so double the wire. But I could add more panels without being clipped.
This was initially my plan but when I emailed SRNE asking about a larger capacity parallel inverter they didnt respond. I will need to be setting up my system this summer so I need something by then. The HYP versions people mention on here that are stackable I cant seem to find at a canadian supplier. I dont really want to deal with ali express since if I have problems with the product I'm probably on my own.I would wait until SRNE releases the 10Kw version that can be put in parallel. It should be released soon. If you plan on expansion or need the inverter capacity, that may require parallel units.
SRNE informed me it is coming soon.
This will also increase the number of MPPT's so no need to parallel strings.
No, my point was that the 6000xp allows even less solar input both in watts as well as amps. I believe each input on those is rated for something like 17a. The voltage limit is close enough or possibly the same that while you may potentially gain one panel in series, you’d lose an entire parallel string per inputya i realise I wouldnt be able to parralel with a 6000xp for sure so double the wire. But I could add more panels without being clipped.
they’ve told me that since OctoberSRNE informed me it is coming soon.
No because I am comparing buying two 6000xp to one ASF 10k. The max watts for pv input for the SRNE is 11000 and the max watts for two 6000xp is 16000. The amp limitation means paralleling panels is not logical but the amount of panels i can connect or at least the watts I can get out of them is higher with the 6000xp. Voltage limitations are identical and idle consumption is the same. My reason for wanting the SRNE though is the cost of one 6000xp is pretty much the same as the SRNE, plus if i parallel panels I save on wire.No, my point was that the 6000xp allows even less solar input both in watts as well as amps. I believe each input on those is rated for something like 17a. The voltage limit is close enough or possibly the same that while you may potentially gain one panel in series, you’d lose an entire parallel string per input
Yes you would.The panels Im looking at are about 13.5 amps each and I would like to parallel them but since the max draw is 22 amps I would lose a fair bit in ideal conditions.
If they are angled appropriately you will lose out on a fair amount in ideal conditionsI also wonder if over paneling it would reduce the lifespan, my idea was 6840 watts per mppt input.
That's exactly what I would do if I go with another ASF.You mentioned adding more inverters, Im curious how you do this without paralleling them? I dont really undertand how I could expand on this system other than running seperate electrical panels for each AIO.
Personally I wouldn't based on my SRNE experience. Iirc the 6000xp has a lower current rating per mppt than the SRNE.Makes me wonder if I should get a couple 6000xp instead for ease of expansion but the cost would be practically double.
I got you now. That makes more sense with 2.No because I am comparing buying two 6000xp to one ASF 10k. The max watts for pv input for the SRNE is 11000 and the max watts for two 6000xp is 16000. The amp limitation means paralleling panels is not logical but the amount of panels i can connect or at least the watts I can get out of them is higher with the 6000xp. Voltage limitations are identical and idle consumption is the same. My reason for wanting the SRNE though is the cost of one 6000xp is pretty much the same as the SRNE, plus if i parallel panels I save on wire.
You mentioned having significant gains in winter simply by adding a very small amount of panels and a victron. What is it about the victron that is giving such a benefit that the SRNE isnt providing?View attachment 199315
I have the wired 7s2p on MPPT1
Yes you would.
You could aim your arrays different directions and parallel them, that's how I have MPPT set up. 9s2p 315W Q Cells aimed S and W.
I may have worded that poorly.You mentioned having significant gains in winter simply by adding a very small amount of panels and a victron. What is it about the victron that is giving such a benefit that the SRNE isnt providing?
1 random fault, 0 major issues.
I would not hesitate to order again or recommend it to family and friends.
I'd be over 3MWh solar if I didn't add the Victron to squeeze out more production in the winter and/or if I had more dump loads.
It was something related to communications, fault 12.Fantastic news! what was the one fault? I have the same inverter but its only being used a charger right now.
I didn't have to restart, it didn't restart. It just went away, and hasn't been back.Does it automatically restart, or does it have to be manually restart after error? Could be problematic in an unsupervised remote off grid location.
