I don't have a major setup... it's 2x 180watt in series. (72cell each, 36volt each. So in series it's 72v or 73v. The amps are less so it's around 4.89amps per panel. Due it it being in series , the amps stay the same. The volts double)I have 4x 2w 5v 500ma panels soldered to a microusb and schottky diode. It charges my 3800mah power bank over a cloudy day. That was my first real solar project not counting charging AA batteries with those lawn lights from the dollar store and an incandescent bulb.
Whats your solar setup?
Some people connect 2 panels in parallels , which will then be 36v x 9.78 amps (4.89a x 2) = 352w
mine is 2 panels in series, which gives 72v(36x2) x 4.89amps = 352w
Most wires that are 2-3mm thick copper can handle volts upto 110v or even 220v. (like check your normal extention leads wires on inside. they are fairly thin). The amps on other end. If your pushing 5amps it can be a thin wire. Where'as pushing 10amps over wire , that needs a thicker lead.
Efficiency on 72v is also much better... due to mppt and how it acts on volts to produce watts. If a normal 12v panel was used which produces around 18v or upto 20v. The mppt gets more efficient if it has higher volts (at least 3-4v above the 12v or whatever your battery capacity is) . That is why mppt is better than those PWM chargers. So if you buy a solar panel that is 24v which pushes real volts of 33v to 36v. MPPT is very good.
Pushing it upto over 60volts makes both panels super efficient .
i'm running 2x 105ah Deep cycle battery's. (both in parallel). This is kinda my downfall. As my inverter is 12v 600watt Pure Sine wave. I can't push my battery setup to 24v.
Cause i could connect my battery's in 24v (just a cable change) then i would get much more bang for my buck. Then i need a 24v Pure sine wave inverter.
