So, here is my battery graph for most of today.
You can see that from midnight to 6 am, it was slowly charging at 10 amps. At 6 am, the PLC took over and decided to use that stored power. But the sun was also coming up, so the current form the batteries went from 20 amps, and ramped to zero at 8 am, and by 8:15, it was charging off the extra solar beyond the house draw.
I am only taking mine down to 51 volts, so that is where I have been starting. The slow overnight charge of 3.3 KWH brought them up to 51.85 volts. The morning 1 KWH used, took them back down to 51.7 before they were charging again. The PLC was doing it's job, trying to charge with as much of the extra solar as it could until 11:50 am, when I unplugged the PLC. That froze the current at 39.5 amps, but after noon, the A/C kicked on, so I dropped the charge current to 27 amps. Charging at 27 amps, the voltage climb is very linear. Total for the day, I pushed 12.7 KWHs into the battery bank. I got the voltage up to 55.3 charging just from sun, and using grid to power the house and my A/C. Some solar was also helping run the house as the solar made 26.4 KWHs today. At 3:20 pm I was going out, so I plugged the PLC back in. The A/C was running, so i dropped the charge current back to just 5% 7 amps. At 4 pm, charging stopped, and the PLC went to work making the batteries zero my grid power meter. The A/C stayed running until almost 5 pm on that first cycle. The extra current from 4:30 to 4:50 may have been a refrigerator defrost cycle. Or my son was gaming on his PC. Since there was still sun, the batteries only needed to supply 40-50 amps. From 5pm, to 6:20, the A/C stayed off, and the solar ran the house, and exported a bit. A/C kicked on again, with less solar and the battery voltage a little lower, the current is now 70 to 85 amps as the sun goes down. With the A/C off, the current increased as the sun went fully away at 7:45 pm.
It made it past 9 pm on battery!!
The A/C kicked back on at 9, and you can see the grid support cut off and back on a couple times as the battery dipped back to 51 volts. When I zoom in I can see it was 5 times in the hour before the A/C cycled off again. The battery has rebounded to 51.2 volts, and is running the house with just a 21 amp draw on the battery. It will be shutting off for the night soon though.
So how does this compare to last year? I am 1 day shy of getting the total bill, but I will estimate another 20-40 KWHs tomorrow, bringing my June-July 31 day total to just 180-200 KWH of grid power. Last June-July, 2021, I used 540 KWHs. So even with this insane heat spell, I used well under half the grid power, and very little was peak rate. The bill last year was $68.14 the estimate this year, with the rate and tax changes is $55, but I won't have the exact number for a day or 2.
And YES, the SHTF, good one. Now I need to buy some of that spike strip stuff to make it so the birds can't s#it there.
My dad's friend liked using big words, so it was "The excrement has contacted the ventilator"
