ArthurEld
Solar Wizard
Green scotchbrite should be good enough for new cells.So how would I know if this is aluminum? And I would just scrub around the stud right?
If you get loctite on the terminals or bad oxidation you'll probably need to use fine sandpaper. And that is no fun when the stud is in the way.
Edit: The terminals are aluminum
