Ok so I am still trying to decide on an all in one hybrid low frequency split phase inverter for my rv build. I want the system to be as simple as possible. I wish I could afford a sol ark but not today.
I have so far limited it to:
sigineer:
And sungoldpower :
Cost is basically the same.
From what I can understand these are both clones and the biggest difference is the sigineer is 40 lbs heavier? ? I'm concerned about the db of the fans of both, but I've read you can replace the fans with more premium ball bearing ones.
I want to buy 48v 200 amps of preassembled batteries to make it simple. I'd like them to communicate with the inverter as much as possible.
Sungoldpower has them $1000 cheaper than sigineer
Do you think the batteries are interchangable between inverters??
I think I want the sigineer inverter and sungoldpower batteries. But if they won't communicate I could just stick with all sungoldpower...
Any thoughts? Many thanks!!
sigineer:
Solar Power Inverter For Home 12000 Watt 48V to 120V 240V w/ 120A MPPT Controller ETL Listed
12000 Watt Solar Power Inverter For Home |120A solar charger Pure Sine Wave 48V dc to ac 12KW 120/240Vac, off grid, emergency backup power
www.sigineer.com
And sungoldpower :
12KW Hybrid Solar Inverter UL1741 Standard
Hightlight: ★ All in one unit: This power inverter for solar panels is UL1741 standard, integrated with a 120/240V 12KW split phase off grid pure sine wave inverter for houses, 80A AC charger, MPPT solar charge controllers and a transfer switch in one package. ★ Low Frequency best hybrid...
sungoldpower.com
48V Lithium Battery 200Ah 10KWH Deep Cycle for Solar Systems
www.sigineer.com
48V 100AH Server Rack LiFePO4 Lithium Battery SG48100P
Highlight: ★Character: The 51.2V 100AH LFP Battery is compact, well-designed, LCD, and cable/accessories ready for installation. ≥7000 cycles deep cycle & 10 years warranty, designed for up to 15-year life. ★Intelligent BMS :Battery Management System can manage and monitor cells information...
sungoldpower.com
