A 12oz spray can of paint is usually 8-9 oz of actual paint but you don’t usually get it all out . A mini paint gun is usually 4-5 oz paint and can add bigger cups. They are best paint guns for small things and some small guns you can put bigger cups on them. If you have local HF check them out.
These small guns work best with small air compressors. Large paint guns take to many cfm to atomize properly - need big air compressor. You might skimp by because the golf cart is small..
HF mini gun the previous version worked great….and was cheaper. It is gone This one looks to be built better. Resembles an expensive SATA gun.
Paint mid day not as many bugs…they love fresh paint die on it. Don’t paint when bugs are out like dusk - night. Solid colors are best - easiest.
![IMG_6081.jpeg IMG_6081.jpeg](https://diysolarforum.com/data/attachments/209/209730-5e39ada6fbfb3d0bdfd90b4888119dc0.jpg)
Tractor supply Paint colors are limited. You could go to automotive paint supply and get a ss urethane and hardener doubt take a quart. Call talk to them in your area. Don’t get none of that water based shit.
This Paint once hardener has been added has to be sprayed or left to be dried out-than discarded afterwords. You will Need thinner too. Follow directions.
Take picture of label on can because after first pour paint will get on it.
![Rolling on the floor laughing :rofl: 🤣](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f923.png)
That hardener decreases dry time and according to label “No Isocyanates.” They took the tech sheets down so maybe the instructions are on the can. Again get their recommended thinner if you decide go that route. Brake cleaner from “O’Reilly” auto parts works well for cleaning your paint gun. Remember paint is reflection of surface prep bad prep shows and paint won’t hide it. I diy to have tools for next project. Save money too. Most paint rattle cans if you go that route work best if you line nozzle up with spray mark. I prefer mini gun.
I think Evercoat makes best fibreglass and bondos. Follow directions. Bondo has very short working time before it kicks. Follow directions.
Got refund for my Mpp Solar wireless dongle …..saved that $100. Ordered it several days ago and they send email wanting all my inverter info. I asked them to just cancel. Got Solar Assistant on it. Going to add my Victron shunt and tie it in to Solar Assistant. I think battery reporting will be more accurate afterwords.
