TommySr
is your AIO split phase or do you use a transformer?I like transformers too but my HF SRNE has really been impressive so far
Split phase. https://diysolarforum.com/threads/3-mwh-srne-asf48100u200-h-10kw.67809/is your AIO split phase or do you use a transformer?
Never heard of that brand look like AIOUnderstood.
Makes sense.
Don't have to deal with code enforcement if they don't know about it in the first place, "land of the free"...
I like transformers too but my HF SRNE has really been impressive so far (it's still early though, getting close to 4mWh solar through it...time will tell).
I'm very temperaturemental myself... Minisplit down around 62F and I sleep like a baby, then flip it to heat to get out of bed
Understood, just don't want to see anyone unhappy with the issues running 12V LiFePo4 in series can bring about.
Not rejects, to cool for everyone else
Lots of the trolls here aren't doing a damned thing with solar...
It started as hobby for me, might be an addiction now... Energy independence....
Yea I have ~11kWh of panels up (I started with 200W...) and it's not enough for winter, even with ~40kWh of DIY LiFePo4...
420OhmsPA, they got me on the price, I got a transformer 7.5kw cheap($200.00) but the thingI considered going with 230V European version because they are so cheap
That's not a bad price. Battery Hookup should get more attention here.Never heard of that brand look like AIO
‘’HF SRNE‘’
They govt basturds see the obvious solar panels and don’t know what to do. Govt Intruders. The govt is searching for money in any shape form faction to fee grab. Going to get worse. Ppl in germany use to be taxed for furniture and shit inside homes.
Anyway I took my little arrays down - moved back into garage. They were in way of new building coming in. Damn the buildings are expensive now. They are crazy with 10x10 shipping containers prices too. I was going to set everything up in one 10x10 away from house. Spray foam inside to insulate. Mount few panels high and low on it too. Still thinking about it but just get 20 ft shipping container mount panels on top and side. The 10x10 cost as much as the 20x10.
12v in series are managed with bt monitoring. I would not run them without bt. The heaters mean they draw down uneven …. I throw fire at each 12 volt individually while connected but 52.1 v circuit breaker opened. Heated batteries are good - bad.
These batteries caught my eye too.
Damn that's a fuck ton of idle consumption. My SRNE 10Kw is 100W. My old TP6048 was 135W.420OhmsPA, they got me on the price, I got a transformer 7.5kw cheap($200.00) but the thing
draws 200W idle![]()
420hmsPA, I'm checking SRNE none, 100W I could live with.My SRNE 10Kw is 100W
They are rated for series and parallel operations. Why like Will opening the batteries up for us to look inside.That's not a bad price. Battery Hookup should get more attention here.
I'm using JBD BMS as well, no complaints besides lack of active balancing.
Also check out 18650 Battery Store.
Biggest issues I've seen with 12V in series is not staying balanced... 1 pack gets outta wack and you're up shit creek without a paddle. Just make sure the BMS components can handle the 48V (60V)...
Case...They are rated for series and parallel operations. Why like Will opening the batteries up for us to look inside.
I have looked at these on that website too. There is a nice rack server like case for them too. Damn case cost around $500+ and have to order Ali-express.
Thanks.Nice….. RACKs![]()
If they go poof I'm doing something seriously wrong or have much bigger issues to deal with. Packs rarely see over 0.3C charge and discharge.
These?Those surge arrestors you have for boxes can be good or bad …. Most times they cause a fire too.![]()
The house grounding is critical most ppl do not ground home properly. Some codes require 2 grounding rods within “x” ft of one grounding rod to another grounding rod now. You will have to look up the new codes.Thanks.
These?
sounds like an MOV type device (metal oxide varistor)The old surge strips many years ago for computers were 1 time deal had to repair them if suspected lightning.
Makes sense but some ppl still use the deep cycle. Just get 50% DOD.after seeing the performance of these Lithium batteries I'm pulling out
all the flooded acid batteries (12-12 volt deep cycle cheap walmart batteries)
they can't even compete with a 100Ah Lithium battery.
D71, thanks for the heads up, I'll keep that in mind when I set my auto grid charging program.If you hammer those lithium - Lifepo4 with heavy discharge and recharge will kill them too.
I’m no expert. At anything.D71, thanks for the heads up, I'll keep that in mind when I set my auto grid charging program.
the lifep04 are currently set to grid charge 25A when they drop below 24.5V and stop charging
when charging current goes below 5A.
I may set it to auto grid charge below 25V for my 400Ah 2p 24V pack
for my Lithium Ion battery pack it set to charge below 22V 100Ah 7s12p 24V pack
D71, looks like I need to reduce my charge cut off voltage. now is 29.0 the manufacture says 28.8VMy batteries like most have a max charge amps recommendation from manufacturer
D71, yes for the arduino's I use C++ programming language in the arduino IDEAre you running the Arduino library?
I have looked at the ESP programable chips because of their prices (every low)Have you messed with these?
D71, now you got me in tears, when a built my Lithium Ion battery pack I added a wire for each cellOne big screen for every thing would be the berries. I think an alarm on battery cell over voltage would be wise.
the dashboard on the remote windows PC I wrote in Visual Basic programming language
because I wanted to keep long term data in Microsoft Excel format. Visual Basic is very good at that.
the reason I stay with Arduino devices is mostly habit, and I find them to be very
reliable, never have to replace them(sweet!) having multiple serial ports is also
handy, the arduino mega has 4 RS232 hardware ports(sweet!) I have used their
hardware serial ports at 500000 baud rates with good, reliable communications(sweet!)
to record and monitor cell voltages, but the LiTime 24V batteries I got ($1200 each) didn't have a port
outside the battery or even bluetooth, I was thinking of cutting them open to add a port for cell
voltage, but that $1200 each stayed my hand (crap!) after I get some use of of them maybe I'll get bigger
balls.
