Do you need 220-240 volt split phase?
This stuff gets expensive real quick. Mistakes are a biggie waste of money. Why I was asking.
Some things for the future….to consider. Victron is probably best advice and I just don’t see problems like from cheaper units.. Expensive. Very Low watts in standby.
I considered setting up multiple remote solar power stations then running a power wire to appliances. Or setting most everything up at the appliance. The problem think most of us have is trying make solar fit our life styles and as such adapt these systems to our conventional past. That might be a mistake and need to do things different for multiple setups….vs single source.
Again THINK; We kind of need to change up everything for thinking. I like these Victron small inverters might be solution because in no load - eco mode the rated draw is just 1 watt or so. Of course if mppt is sitting there powered on then it is drawing juice if solar is not off setting it. Most ppl with systems like this should NOT compare to all in one units for idle. The watts while at idle for all in one systems when running everything inverter, mppt , built in charger and so on is going to be a bigger draw vs stand alone inverter.
That Parasitic drain is a problem…for small systems….. i am considering this to basically run my refrigerator or maybe bigger version run refrigerator and chest freezer . I have 120volt 1 ton mini split heat pump might run with victron 1200va …24 volt unit. The 120v -mini heat pump takes a lot of power. I started get the HYBRID unit that just plug panels into from signature solar but wanted batteries to dampen the load…in regular system.
This HYBRID IS INTERESTING. BUT I went with standard 120v 1 ton mini split direct from Pioneer online.
EG4 Hybrid Solar Mini-Split Air Conditioner Heat Pump: 12,000 BTU, SEER 22, Energy Star certified, designed for easy DIY installation, ensuring efficient and eco-friendly cooling/heating.
signaturesolar.com
I also changed out my electric water heater for a lpg tankless on demand water heater. It saved a bunch of money and electricity…… I have installed a few lpg tankless for other ppl. See below.
The versions vary depending on what you need.
Specific use applications like refrigerator
I am considering this for my mini split heat pump.
I think we sometimes need to completely re-think our applications with a fresh approach vs adaptations over from past traditions. Some of these inverters come with gfci sockets which think is my preference for direct plug - protection. I think appliances with built in battery and inverters would be interesting just plug up solar panels…option 120 volt selectable. These systems do nickel dime with other components like mppy and a battery charger for when the solar lets you down.
Before you buy anything else try your setup for testing your present system… see what you think before spending more. Better to learn with your current setup then spend more with defined goal. Some ppl spend a lot of money.
For hot water - tankless have seen these working fantastic for 4-5 years zero problems and they come with exhaust kits. Not for large homes and best to setup near the most used source for hot water. Recommend getting the water valves from home depot or lowes. Electric hot water heaters are just not a good method to me…when conserving energy. Traditional electric water heaters are hogs. Best money saver so far.
Low-cost and high-performing indoor liquid propane tankless water heater. Sleek design, automatic temperature controls, and LED touch screen display.
www.eccotemp.com
They are offered for $349 at Lowes now and you can get 10% for being in military - basically no taxes. Eccotemp sells direct.
I hate plumbing …. These units always require thought to put in the cleaning valves.
I think ppl need to re-examine how we build homes and have energy combined central points vs spread out big homes. The Swedes and Japanese are good at compartmentalized living spaces.
So what are you planning?
You want to go Green don’t you?
