In lithium mode 28.4VOk so I read the manuals of 21 of them and they all charged to 29.4 volts.
Again, thanks for the link
I did not see anything saying it could be put into "lithium" mode.In lithium mode 28.4V
I didn't see anything in their manual that said this. Sorry.You can configure it via the Victron Connect app on your cellphone or tablet, using Bluetooth.
Look about an inch before that where it says "High:29.4"
Correct ...you use the Li-ion setting...not the 29.4 settingLook about an inch before that where it says "High:29.4"
Also, lifepo is not Li-ion.
I can only go by what the manual says and not what you WANT it to say.Correct ...you use the Li-ion setting...not the 29.4 setting
And yes...LiFEPO4 is a form of LI-ion battery. That voltage setting of 28.4V is perfect for LiFePO4.
This is my last post helping you....obviously you can't listen and have some strange preconceived ideas that hamper you from learning things.
Can storage and float get disabled also?I would probably set it to custom and run 28V absorption voltage and 26.4V float, for better battery longevity.
You can disable float, but not storage.Can storage and float get disabled also?
The Victron manuals are not always great, even though they technically contain all the info you need.I can only go by what the manual says and not what you WANT it to say.
LOL...I am reading directly off the manual.I can only go by what the manual says and not what you WANT it to say.
Thank you. So in the app they let you choose what the highest and lowest will be? Pretty cool.Here's a screenshot from the settings page for that charger in the app, with li-ion (really: lifepo4) preset:
I would probably set it to custom and run 28V absorption voltage and 26.4V float, for better battery longevity, like this:
Ok then if I am hopeless then why can't anyone else find what you claim to exist?LOL...I am reading directly off the manual.
I am done...you are hopeless.
Ok thanks. There is nothing on the data sheet that says this sadly.You can disable float, but not storage.
It's in the app store on your cellphone if you have android/iphone.Heck, I was not even able to find the link for the app either.
So what do I do, look for Victron at the google playstore?It's in the app store on your cellphone if you have android/iphone.
Ok I found five apps there.It's in the app store on your cellphone if you have android/iphone.
