Has anyone had trouble uploading the new firmware to EG4 LL V1 batteries?
I've been trying to upgrade my V1 batteries in order to run them closed-loop via a V2 battery with my Schneider XW Pro. I'm able to monitor the batteries just fine using the BMS Tools program and the USB/RS485 adapter supplied with the batteries by Signature Solar. However, I'm getting "Update failed, check BMS connection..." errors when I use the PC Updater 9600 tool to update the firmware. Evidently the updater tool is not communicating with the battery. Battery address is set to 0000, same symptoms using multiple computers and multiple com ports, etc. I'm baffled...
I've got an email support request into Signature Solar on it but no answer back yet. Has anyone else run into this problem and if so what did you do to overcome it?
Thanks...
Thanks...
