wopachop
Would a cell like this be a bad choice for vehicle mounted?
I don’t think it should matter much if these are grade B cells for use as vehicle mounted ESS.Would a cell like this be a bad choice for vehicle mounted?
If you build you pack correctly , what gives you the idea they will go down shaking ?Was thinking a poofy pack might not be the best to go shaking down the road. Like its already injured.
Other idea is the cell is already beat up, so i wont worry about shaking down the road.
Also i pictured strapping them somewhat snug.
Back in the day lipo batteries that puffed were considered not as shelf stable. Does the same apply to LifePO4?
Mine fit in my EEL case (well so far 16 in one case, haven’t tried the second) so I think there should be enough security from movement down the road. Each set up is unique though and may need additional scrutiny or safety measuresWas thinking a poofy pack might not be the best to go shaking down the road. Like its already injured.
I probably wouldn't for the simple fact the cells need to be secured to prevent the cases from rubbing together and to prevent terminal damage. Another is whether the cells would get less bulged over time or try to bulge more and put stress on the terminals.Would a cell like this be a bad choice for vehicle mounted?
You'll want to test them all if your going to hold them to it. Mine have all tested at 299-300.Just purchased 17 of the grade B cells from 18650. $89 dollars. Was told by James that these cells will pull 305 Ah capacity, I plan to hold them to that. They did mention swelling, I'm ok with that since they will be sitting on a shelf, compressed... Will update as needed
how do you know your meter is that accurate? thats a less than 2% variation. I have multiple different amp meters, both clamp and shunt, they are never within 2% of each other. also did you completely top balance all cells before testing?You'll want to test them all if your going to hold them to it. Mine have all tested at 299-300.
Even the tags on them indicate they tested at the factory at just over 305. Assuming they lost some capacity over time sitting.
Personally, I don't care if these test at 295Ah or 305Ah. Heck, even 290 is okay by me. I paid $79 per cell and I don't really care if I lose on 3%-4% capacity for that price.
All of my cells were had minor swelling. I would say stacking 2 cells side by side, the gap was somewhere b/w 1/16" to 1/8".
I have been contemplating buying more of these cells, since all the ones I tested (4 of 33) were over 300Ah and swelling wasn't too bad. Looks like I'll have to wait for some other deal. Interesting enough, it's letting me add another 32 cells in the cart and go through most of checkout steps ?When I called them, I asked specifically if the capacity is as specified in the listing for the grade B, he said yes they are and some higher. 300 Ah will be acceptable to me, 290 is not. BTW,, I tried to get them to come down to $79 dollars but he said the only had 21 in stock as of today. As for the swelling, that would be fine if they are only 1/16" to 1/8"
Yes it does, hmmm...I have been contemplating buying more of these cells, since all the ones I tested (4 of 33) were over 300Ah and swelling wasn't too bad. Looks like I'll have to wait for some other deal. Interesting enough, it's letting me add another 32 cells in the cart and go through most of checkout steps ?
Thanks for the update on count for what they had left.When I called them, I asked specifically if the capacity is as specified in the listing for the grade B, he said yes they are and some higher. 300 Ah will be acceptable to me, 290 is not. BTW,, I tried to get them to come down to $79 dollars but he said the only had 21 in stock as of today. As for the swelling, that would be fine if they are only 1/16" to 1/8"
You need the correct meter for the job, one of these. https://shop.snapon.com/product/Com...racy/TORQOMETER-U.S.-Metric-Follow-up/TEC3FUAI snapped 2 lugs off whilst using a torque meter for the first time in my life
