Are These What I Need and is the Price Fair
guidecca
I am buying Lifepo4 batteries from Shenzhen Basen Technology Co., Ltd. (see attached invoice). Does this price look like fair market value as to the batteries and the shipping? Thank you.
You need to use the Chat function, contact the seller directly and get a custom quote. Don't just use the Alibaba interface and its quoted shipping costs. Also, search the forum and see what others think of the seller; make sure you have the right expectations.
Okay. Thanks. I get a "Send Error" when I send to Alex Chen. Is the object of the custom order to bargain for a better price or something else? My goal is to increase my current storage which is two 12v 100aH Lifepo4 wired in series for my van.
You don't bargain - you just get a custom quote based on what you need and where you are located. The shipping price calculator on Alibaba is always wrong - don't rely on it.
This is the one you want to contact:
Also, make sure you have DDP Incoterms. I noticed you have DAP in your original one. DDP makes sure you don't have any extra costs such as taxes.
I bought 16 280AH Basen LF280K cells from another member here last week for $158.75 per cell. In other words, ~$1270 for 8 cells.
I'm still waiting on 20 Lishen cells from China that I ordered back in February that haven't even shipped yet. It felt like a relief to buy from a domestic reseller and have the cells in 2 days. I have nothing but good things to say about bossmav
After you get DDP price from your seller, it might be a good idea to consider your options.
If I bought eight cells how would that compare to the two BB 12v 100aH batteries I bought. I'm trying to power a portable air conditioner. I have a 24v system and wonder if I would be better off with a 12v system. How would 16 cells compare?
8 cells (280Ah each) would give you 2 x 280Ah @12V batteries, or one 24V 280Ah battery. Energy in both is the same: 7 kWh or thereabout, compared to 2 x 1.2 kWh for your BBs. If you make it 16 cells, you can go 48V 280Ah, for around 14kWh of storage. Or 2 x 24V or 4 x 12V with these 16 cells - energy stays the same.
To run an AC, how much does it draw? Suppose you have a 1kW load (continuously), 8 cells could run this for about 7 hours (not including inverter losses, it will likely be closer to 5-6 hours). If you have a 3kW load, you get 2 hours. Double the cells, double the runtime. The higher the load, the higher you want your battery voltage to keep the current low (P = U x I).
2 BB 12v 100Ah batteries = ~2.4 kilowatt-hours of capacity
8 280Ah cells = ~6.7 kilowatt-hours
16 280Ah cells = ~13.4 kilowatt-hours
In other words, a 16 cell 280Ah battery would have around five and a half times as much capacity as the set of 2 BB batteries that you have.
It's much more complicated to assemble a pack than it is to buy a premade unit like the battleborns.
edit: upnorth already covered it all, but It seems like he hit post 2 seconds before I did haha
If the batteries were available how many BMS's would be required for a 24v system. Are BMS's readily available? Would there be a easy guide for assembling the batteries? Any special equipment required? Suitable for installing in a van? Is this a path I want to go down given the price and availability of $500 batteries? Also, if I had 6 BB 12v 100Ah batteries or a $500 knock-off I would have 7.2 kilowatt-hours. Don't know how robust 6 batteries are but they come with a warranty in some cases.
