Partimewages
I wish we would just go to KW everything from everywhere else is so I am always converting!
What the hell. We are having close to -30C and winter hasn't even started yet?Winter Solstice is Thursday December 21st @ 10:27pm EST in. North America this year. This corresponds to Friday, December 22, 2023 at 03:27 UTC.
So yes, depending on your location Winter may start on the 21st or 22nd this year.
Look at those big old GARN batch heaters.I've been reading in the forums over on Hearth.com. Interesting reading when it comes to buffer tanks. The move has been towards gasification boilers combined with buffer tanks. Some are building buffer tanks out of 500 gallon or larger LP tanks, using spray foam insulation on the tanks after modifying and cleaning the tanks.
The idea is an efficient burn with only firing the boiler once a day or 1.5 days. UpNorthandpersonal uses a gasification boiler with about 800 gallons of storage. https://medium.com/@upnorthandoffgrid/6-heating-systems-5c5727c1607e
OzSolar uses an even bigger buffer tank and fires once a week. https://diysolarforum.com/threads/feast-or-famine-the-off-grid-solar-dilemma.63293/post-809392
Using an air to water heat pump with a large buffer tank is probably the way of the future. 1500 gallons of water heated on days of good sun to be able to go thru the days of no sun.
BTUs all the way. I have kind of a clue how much heat it is. How it translates to watts I have no clue at all.Are you guys still using British Thermal Units over there? We stopped using them at the end of the last century
Pretty hard to get that down in my basement plus the solar takes up one whole corner.Look at those big old GARN batch heaters.
They have something like 2000 gallons of water around the fire jacket.
It’s like an old steam locomotive but for heating houses.
Yea they usually build a separate building for them.Pretty hard to get that down in my basement plus the solar takes up one whole corner.
I purchased a boiler already, it goes into building we will build next summer. Pipe the hot water over to the house where the buffer tanks will be located. The boiler I purchased only holds 59 gallons. That should work well with 200 to 400 gallons of buffer tank.
You will be getting it.You mean there is more coming ? ? ?.
Since the beginning of the month I've tripled my array size and quadrupled my battery bank plans when I build completely off the grid....
View attachment 181204View attachment 181205
Sweet, I just love that weather.You will be getting it.
Fog this morning, sky was clear. As soon as the sun just about cleared the fog layer, it cloudy over, completely gray sky all day. It was dark here by 4 pm. Damp as heck too, the cold just seeps thru clothes.
I hear you have a BUNCH of panels available for thatYup
December sucks. Not looking forward to January, either.
I'm going to throw a bunch of panels on the ground, in the back yard.
What the hell, it can't get worse.
I find the ice is not as much of an issue as snow, if you can brush off the snow, the next sunny day will melt the ice as the panels start to generate even through pretty thick ice, takes a while, but it warms up enough for the ice to slide off.Blergh, too much snow and freezing rain up here in Ottawa ??
12.35kWp of panels w/Tigo TS4-A-O means nothing when there's 6" of snow on top of everything...
Yeah, I grabbed one of these roof rakes that has a super soft head, and it works pretty well at getting the snow off the bottom row of panels. Need a longer pole and probably a ladder to reach the upper row though ?I find the ice is not as much of an issue as snow, if you can brush off the snow, the next sunny day will melt the ice as the panels start to generate even through pretty thick ice, takes a while, but it warms up enough for the ice to slide off.
I got the 18’ version of this, they go to 24’Yeah, I grabbed one of these roof rakes that has a super soft head, and it works pretty well at getting the snow off the bottom row of panels. Need a longer pole and probably a ladder to reach the upper row though ?
Yes it did a few miles east too.Today sucked.
Made 11kwh.
I have one of extendable window washer aluminum poles with the 20” wide soft squeegee. Works good for cleaning them and brushing snow off. Didn’t have enough last winter to worry with.Yeah, I grabbed one of these roof rakes that has a super soft head, and it works pretty well at getting the snow off the bottom row of panels. Need a longer pole and probably a ladder to reach the upper row though ?
Made 9.9kw here in a 13.6 system.Today sucked.
Made 11kwh.
I agree and there are even some situations where straight resistance will make sense. EG: I'm nearly done adding a 11kW straight resistance my 1200g storage tank. I've modified a 50g water heater so it can run both 5,500 watt elements at the same time. I've nicknamed it the "kWh eater".Using an air to water heat pump with a large buffer tank is probably the way of the future. 1500 gallons of water heated on days of good sun to be able to go thru the days of no sun.
