Were they referring to a power supply or charger?
I don't know why the Riden isn't called a battery charger. Where the wires are connected it says for charging batteries.
I'm sure there is some technical reason not to call it a charger. But the word charger pretty much explains what I am doing in one word. Power supply is two words and it doesn't explain what I am doing with it.
When I charged my batteries using the Riden in charging mode the charger did stop when the batteries reached 14.6 volts at 100ma. My regular LifePo4 charger stops when the battery reaches 14.62 volts at 500ma.
I don't know how it's going to behave charging at 3.65 volts. I suspect it will behave the same way but I sure will be watching it. I might call it quits when the cells reach 3.55 or 3.60 volts.
But that was not my experience...not even close. Are you referring to the 120 amp power supply you have? Perhaps that is my misunderstanding.
The Riden displays 3.65V but if you look at the coulomb meter or the BMS volts it's not at 3.65V. Then the Riden reduces the amps which technically isn't reducing the voltage but the battery never actually gets to the 3.65V. Besides that it hangs at the 3.65V area for too long. That is different than if I use the BMS to stop the charging. When I use the BMS it charges full blast until the BMS reads the battery is at 3.65V and then it cuts off the charging. There's no hanging around at the top. This is very hard to explain and I am just repeating what I heard someone else say.
I'm very inexperienced so I am not trying to say that I understand much. But this is the subject that has been in my mind for a long time.
The issue I am describing above is much worse with a 5A power supply.
Something else I realized is that 48V at 12A isn't really all that wimpy. Riden 48V x 12A = 576W Mean Well 3.3V x 120A = 396W
The Mean Well is more powerful for parallel configuration charging. Or charging single cells. But it is faster for me to charge 16 cells in series with the Riden than it is to charge them in parallel with the Mean Well. And I get the BMS when use the Riden.
At this point I would remove the BMS, connect the cells in parallel then top balance them the traditional way. Better yet, leave them connected in series as
@GXMnow suggested and let the BMS do it's thing with it's active balancers. I understand and respect what you and smoothjoey are attempting. And they are your cells and BMS. But you have a nice BMS and there is no point in risking damage to it. If you decide to proceed with your experiment, I will respect that too. Just be careful.
As far as the risk to my BMS, of course I don't want to destroy it. But I am learning a ton. If I lose a BMS it's $200. That's the cost of 2 cells. I see people destroy 10 or more cells and they still don't understand the BMS. So, I'm not going to sweat it. Besides, it's pretty easy for me to connect my $24 4s BMS to 4 cells to check if the experiment is going to destroy the BMS. That piece of crap 4s BMS I bought has to be good for something.
I realize that GXMnow's suggestion might work. But I am enjoying what smoothJoey and I are doing right now. It is a challenge. Part of a challenge is risk. I will get to GXMnow's suggestion another time. I have watched Will's top balance video a few times and that is great info. But it will do that hanging around at the top of the knee thing even if I use the Mean Well in parallel.
