timselectric
- Feb 5, 2022
- 18,584
Yes, it was right in front of me the whole time. lolPer cell.
It's in the chart, under Daily Balancing.
@Zwy or anyone else who is using the Batrium, do you happen to have a wiring diagram?For 16S, you need a Watchmon Core and a K9.
With 32 cells you can go 2P16S, personally I prefer 16S and a K9 for each.
Don't worry about Blockmons, those are a thing of the past with the introduction of the K9.
You will need some type of shunt trip breaker for critical faults needing to shut the system down. I have a ABB Sace S5N with shunt trip. The Batrium senses a critical fault and trips the breaker. Very flexible system, you can add expansion boards to control fans, PV input shutdown, alarms, whatever you want.
Batrium has Videos.How is Batrium when it comes to support? Do they provide any support for noobs like me or are you on your own? I assume you're totally on your own with the JK-BMS.
The wiring is straight forward.@Zwy or anyone else who is using the Batrium, do you happen to have a wiring diagram?
To get initial setup you would email them and they will provide a link in the knowledge base usually. There is plenty of info on website, the problem is some of the older material like Blockmons is still mixed in there.How is Batrium when it comes to support? Do they provide any support for noobs like me or are you on your own? I assume you're totally on your own with the JK-BMS.
So essentially the Batrium has the ability to monitor the cells over a network and it's possible to use any BMS or active balancer in combination with the Batrium network monitoring?This might sound weird but I use JBD to manage the battery. Since my equipment is about 300 feet away I use Batrium to monitor the cells via network.
You can also add a Heltech active balancer to each one also.
Not had any issues yet.
Use these to connect each cell to each BMS/monitor..
@Zwy @Biasjo @Rocketman
So to summarize, is this a fair summary of the Batrium vs JK-BMS?
- modular ability to expand / monitor / shutdown your battery banks
- ability to monitor your batteries over standard networking cables
- more reliable than a FET BMS
Yes, they do have support. Troubleshooting you will pay for. Good documentation but not organized the best. Aussies look at things upside down I guess.- out of Australia vs China (to me this means support is at least available if not free)
- better software
Disadvantages vs JK-BMS
- more expensive
- passive vs active balancing, added heat generated and some power lost
- more complex / more pieces to the puzzle
I'd say more accurate.- maybe less accurate balancing?
That’s the way I do it.So essentially the Batrium has the ability to monitor the cells over a network and it's possible to use any BMS or active balancer in combination with the Batrium network monitoring?
For example, can I run a JK-BMS and just monitor with the Batrium? And can active balancing be used on the cells in conjunction with the Batrium BMS, or do they end up potentially conflicting?
Checking:
Active balancer BMS - JK BMS
Below bluetooth active balancing BMS also support RS485/CANBus for optional are available for sell: JK-BD6A17S6P JK-BD6A20S6P JK-BD6A24S6P JK-BD6A20S10P JK-B1A24S15P JK-B2A24S20P The abovewww.jkbms.com
So I'd want to buy 2 of the JK-B2A24S-20P
If you have your batteries in Parallel and one shorts out it will draw huge amps to that battery from other batteries and cc so a fuse on the shorted one should go first to eliminate any major fires and what not..@RV10flyer
Sorry for the noob question, but putting a 125A class t fuse mitigates the potential of damage in the event of a JK-BMS or other failure?
The way this is worded can be misinterpreted. If you have a Batrium Core and 2 K9's for each of your 16s batteries it can not shut off an individual battery bank. Your entire system will turn off if one of the battery banks triggers a fault. With two JK-BMSs only the battery bank that has the issue would be turned off so you would still have power from the other bank to power your system.- modular ability to expand / monitor / shutdown your battery banks
I have 10 batteries and I turn one off at the breaker, do any troubleshooting/repairs, make sure the battery voltage is within 0.5V of my system voltage and turn breaker back on. I could run my house on four batteries minimum. I like redundancy. I was hoping the various BMSs's would be a good idea, but most only have 0.15A bal current and have various other glitches. JK is going to be very busy.The way this is worded can be misinterpreted. If you have a Batrium Core and 2 K9's for each of your 16s batteries it can not shut off an individual battery bank. Your entire system will turn off if one of the battery banks triggers a fault. With two JK-BMSs only the battery bank that has the issue would be turned off so you would still have power from the other bank to power your system.
