The idea was to show that 847 can improve connection. Reason for doing it on plated copper is to take oxidation out of the equation for this. The compound (847) is a corrosion inhibitor as well and suitable for use on aluminium contacts for example.
Application of an Anti-Oxidizer on threads is inappropriate until AFTER proper torque is achieved.
Unless you strongly disagree with
the above statement, please do not address the comment as
I am almost unconfused.
So
@upnorthandpersonal would you conclude, considering your experience and research, that 847 outperforms No-ox-ID, Noalox, Ox-Gard or De-Ox under normal (dry to humid) solar system electrical environments because it is an anti-oxidizer and more conductive?
I'm not trying to split hairs, just curious.
Here is some information I found worth noting "from the manufacturers" about the aforementioned products.
MG Chemicals 847
CARBON CONDUCTIVE ASSEMBLY PASTE, Date: 04 March 2020 / Ver. 1.04, Safety Data Sheet
Toxic to: Algae, daphnia magna (largest
(5mm) of the fresh water crustacean genus daphina) and Fish
NO-OX-ID A There are 17 different kinds of "NO-OX-ID"
SAFETY DATA SHEET, NO-OX-ID A, Product Code : 5000-N
Toxic to: Algae, Daphnia (fresh water crustaceans) and Fish
Noalox Contains Zinc powder, which is conductive and toxic to Algae, daphina and fish.
Safety Data Sheet, OSHA Hazard Communication Standard, 29 CFR 1910.1200. Prepared to GHS Rev 3. Revision: C, Date of issue: 08-07-18:
Avoid conditions of moisture or high humidity.
This is the product I have in hand.
OX-GARD While not claiming to be conductive, the manufacturer does state "enhances electrical and thermal conductivity".
OX-400N_TCHDAT_SDS.pdf, Ox-Gard Anti-oxidant Compound
Incompatible Products: Acids. Oxidizing agents
Possibility of Hazardous Reactions: Mixture reacts slowly with water resulting in evolution of hydrogen
Toxic to: Algae, daphnia magna (largest (5mm) of the fresh water crustacean genus daphina) and Fish
Contains Zinc powder, which is mentioned numerous times in the SDS.
De-Ox This may or may not be the product mentioned by timselectric.
ILSCO X-1000, Safety Data Sheet
May cause long-term adverse effects in the aquatic environment.
