MrNatural22
?SW sunshine =⚡️⚡️lit up thru the darkness✌️
So I don't know if this is a PSA or not. I just put the makerhawk loadtester on my battery and it let out the magic smoke. The transistor went up in a plume of smoke. I guess it's my week for messing things up. Good thing I have a bigger 800w load tester I purchased on ebay inbound. Before you ask I did set the makerhawk up for the correct voltage and according to the specs I should have been fine. This is why I hate buying cheap stuff like this.
I went thru the same magic smoke on the first one I bought when I set it at 150watts. They can’t handle the heat. ?
The replacement I got I run at only 130-140w and it performs well. I’ve run many tests at that level with no problem, just takes a little longer. I know these are rated higher @150w but can’t be run higher than 140 to be safe.
Some say theirs can but not going to watch another one go ? Don’t trust that second one to run 180w or it might ?
This is what I got out of the test on my second A123.....down to 2.8 LVD. Took almost 19 hrs @ 135w.
