DELEOCO
If I have if I have a LiFePo4 300 amp hour battery with a 100 amp hour BMS and connect three in parallel, what is the Watt hour and current flow in that system?
Capacity
•900 Ah (11,520Wh)
Current Charge/Discharge
•BMS 300Ah (3840Ah)
Is my assessment correct?? Does the BMS add current flow in parallel hook up
If that is correct;
What size of DC to AC inverter can I use effectively with the above parameters?
Can I run an inverter
2000W w/4000W peak?
or
3000W w/6000W peak?
Thank you for your help!
Capacity
•900 Ah (11,520Wh)
•BMS 300Ah (3840Ah)
If that is correct;
2000W w/4000W peak?
or
3000W w/6000W peak?
