OffGridIdaho
Hobby Farm in N Idaho
Will do......Yes, at least use max amps while using your generator for bulk.
I would also try to up the bulk voltage a little to perhaps 3.5Vpc (or lower if your cells diverge at 28V total). I think your Samlex EVO 1224 charges up to 40A so I'd try most or all of this for bulk.
When your bulk is over, for a full charge that should be about 80% (224Ah) charged (224Ah)/40A = 5.6h
Yes. That is setting up your bulk as above and your absorb:
Set absorb at 3.45Vpc for an hour, you'd probably be at least 90% full.
Summary:
Start with bulk 35A-40A at 3.5Vpc and absorb at 3.45Vpc for 1 hr absorb time. Let us know how it goes and what you've learned.
I will post back how it goes. Most likely wont need to run generator for 7-8 days now. I tiny bit of sun every other day or so extends my run-time.
Waiting for the day when we get bucky-ball nano-tube exotic carbon element 115 (ununpentium-289) batteries that charge in 30 seconds to 1 gigawatt. Wait, I'm still waiting for flying cars from my youth which was 55 years ago so..........never mind!
If only peltier chips were 50% efficient. I have 15 cords of seasoned wood I could burn. Run a copper heat pipe out the wall to radiator fins and 15f degrees with the stove at 550f on the other end. I could compete with a nuke power plant.
