OffGridIdaho
Hobby Farm in N Idaho
I will try to list the facts in order.
Observation number 1
When charging, my cell voltage climbs very very fast. Its as if Im charging a 100ah pack not a 280ah pack. If Im putting 30ah charge into SOC 20% of a 280ah pack it would take aprox 7 hours to charge yet it gets to shut off cell/pack voltage in 2.5hrs, which is not possible.
Observation number 2
Within seconds of charging the pack and termination at high cutoff the pack instantly loses 22% of its cell/pack voltage. It drops from pack V 27.5 to 26.5. I know it was fully charged as I saw the hockey stick climb of voltage right before it stopped charging. This is all 8 cells dropping from 27.6v to 26.5v at the same time.
Observation number 3.
This morning after using 191ah/43% SOC the pack shut off on low voltage while at rest and only a .5ah draw from sleeping inverter. I see a hockey stick down on graph from 25.5v to 23.3v.
Observation number 4
The pack voltage is always at least 20-25% lower in voltage then the SOC meter tells me its supposed to be. Example of last night. Meter said 43% and voltage said 19% with a .5a load. This is a 24v 280ah 3 week old eve pack that is kept warm in a house and never stressed. Normal running loads are 8ah. Max would be a toaster at 43ah for 3 mins. Charging takes place at 34ah.
Observation number 5
My JK b2a20s20p is always trying to keep cell 1 balanced. It spends 99% of its time on that cell. My delta at rest is .003. This morning when pack shut off that number 1 cell was 2.83v and the other 7 were 2.93v and delta was .078 at 0% soc.
Voltages were verified with expensive DMM after shutdown.
Currently I am charging the dead pack and have been charging for less then 2hrs at 34ah. My pack % meter on JK and victron show 30% soc and the cell/pack voltage shows (((26.8v/3.35v<<90% soc))) which is not possible with only a 68ah charge. Victron ah meter shows NEGATIVE -196ah remaining to charge. Which would sync up to the 68ah input over the last 2hrs. All cell voltages are very close to each other so its not one cell bring them all down. It seems like im running a 100ah pack instead of a 280ah pack.
Help, opinions, advise welcome!
