Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,973
this is how coils are made.
Any coils one has seen in the past are rendered obsolete
6 x 300 winds @ 0.4mm. PLA print with 100% infill proofed to withstand the pressure of pushing in the wires.
What environmental conditions are you specifying for your turbine?
I understand native Americans quarried stone by chiseling a groove, putting in dry wood, then adding water.
Also, E-fields applied to water would cause losses. And retained moisture could promote failure of dielectric and corrosion.
Perhaps you can 3D print impervious tongue depressors/popsicle sticks.
Is it possible to fixture metal (magnetic) components and then 3D print around them, to make high Mu inserts?
