the enamel needs to be gone before any kind of connection is put into place
i suspected you would safe the day yes I will just add to the wire ends to make them fit snugle to the wago clamp.Can you crimp or solder in a ferrule so Wago works?
well, he often sees things most of us do not. wether they are magnetic in nature I am not sureIt also helps that you can see the electromagnetic fields.
yess. months later it finaly makes sense. you are correctThe magnetic field needs to cut the windings at right angles, not be given an easier path to bypass the windings altogether.
Let me get one thing perfectly across!! I meant that Hedges is able to help out in cases others are not. That is what I meant with him being able to see things most of us do not. I was not suggesting any mental state nor whould I ever without having a proper PHD.well, he often sees things most of us do not. wether they are magnetic in nature I am not sure
It seems I might be right. PLA is not so bad after allmight be there is no need for carbon fiber filament. I am going to try a regular pla first but this time 100% infill
