You can have alternator near the ground whether turbine has spinning tube or not.
Are your blades airfoils, either in an arc or a rectangle between top and bottom of spinning tube, only connect to tube at ends?
Or, are they paddles (like a split 50 gallon drum wind turbine), and connected to tube full length?
If the former, only thing I see tube doing is taking tension/compression. Which is why I said thrust bearings if no tube.
Of course you need a rigid tower to remain upright. That's why I've suggested guy wires from the top, less material for same strength. With guy wires you might have a spinning tube but no non-rotating tower. In that case, guy wires also need to handle a bit of torque (drag in bearings), like the spokes of a bicycle wheel.
