Every Battery Pack needs to be fused and depending on your voltage you can have some options. For anything that is 36V or lower, you can use MRBF fuses or T-Class fused but over 36V you are limited to T-Class & above. FYI, if using T-Class and such, do use a proper Holder with cover for them. Some folks will "bolt" T-Fuses in-line and that is very very bad ! They cannot take ANY strain whatsoever and can even be pulled apart and that is never good...
I have some "Generic Diagrams" that people here often refer to as a basic template, I'll post them in here for you and others following along.
These are simple Common DC Bus setups for parallel battery packs in one bank.
A-Typical Component diagram | A-Typical AIO Diagram.
View attachment 146947 View attachment 146948
