--Re-posting in the right channel, deleting from the previous one--
I am pretty much a newbie, or rather a reader of the forums here and am looking to do the following
Background
I camp in Tents, and would like to use my lights while camping ( fans, small fridge, etc, no ac). Baseline, I need some power when I go camping, which is about 4-5 times a year, max 5-7 days. Power requirement is about 500-600wh during a typical camping day, so battery drops to 50 percent, but as I have two panels, its pretty much going on.. Most of the power usage during the day is for the fridge, which is pretty efficient..
I had built a 100AH 12V portable battery pack, which I power using 2 ECOflow 160W panels in series. 40v @10amps - https://www.ecoflow.com/us/160w-solar-panel
Purpose
I would like to reuse this battery and possibly add another one in the future, reuse these panels at home. I have the following purpose
1. Run 1 / maybe 2 circuits from this setup. These circuits have the following
1.1 - A server running 24/7 ( unraid ), uses average of 800 wh / day ( about 55-70w load at a time )
1.2 - Networking equipment -24/7 about 1.2kw (100-120 watts constant )
1.3 - Occasionally power led lights in the basement - About 200-300 watts for about 20-30 minutes a day average
The run from Solar panels to charge controller would be about 70ft.
Question
Q1 - Should I be upgrading to a 24 battery setup, by buying an additional battery such as this - https://www.docanpower.com/index.php?route=product/product&path=107_226&product_id=493, stacking atop and getting bigger case
Q2. If I keep my current setup, what wire size should be going from Solar panels to charge controller. I do have a 100ft 12awg copper wire right at home, which I can use, but not sure if that would suffuce
Q3. Charge controller, I did get the Reneogy 100/40 this week, but am thinking should i get Victron 100/20, as I dont suppose I would be pushing more than 20amp at a time, given this is more of a portable setup, so open to options. I am going to be carrying most of this around for camping trips in my minivan
Q4. This one is always tricky, and have seen several discussions on this, but the Invertor, looking at Giandel 1200 Watt to start with ( 12v or 24 v one ), any other recommendations ?
Q5. In my current setup, i just have a compact battery box which is almost similar to this -
, any suggestions on how should I connect the inverter / charge controller, i am currentlly using the Andeson power poles for most of the connections, but I assume i will not be able to connect to an external 1200 Watt invertor with the current wires, the amps would just not justtify the 8 gauge wires which i am runnning to Anderson connectors. I think the charge controller would do just fine.. ( trying to also see if I can put this inside, or just change the box altogether )
Thanks,
J
Background
Purpose
Question
Thanks,
J
