Can AiO use excess PV power to drive their inverters?
Scph9002
A bit wonky question but when I set my powmr (srne) aio to charge my battery at maximum 5 amps, it does just that while still drawing needed power to run its 230v inverters loads from solar.
My aios max battery charge current is rated for 80 amps and max pv power in 6000watt/22amp.. does that mean it can charge my 54v battery with 80 amps/4320watt and run the inverter directly from pv power up to 1680watt until it throttles battery charge amps?
Im used to having the solar charge controller and the inverter as separate things so a solar charge controllers maximum dc output current is shared between battery dc in and inverter dc in
Yes.
High frequency AIO's charge controller feeds its PV power to the high voltage DC bus of inverter.
The high voltage DC bus can supply the battery to HV DC converter (in buck mode) to charge the batteries and/or the PWM IGBT devices that create the AC output.
