That depends on the maximum battery voltage you will see, Most solar distros have 100 amp breakers rated for well over 48v. Not sure the policy on linking to products but here is an example:
The battery specs are
EG4 Lithium battery 51.2V (48V) 5.12kWh with 100AH internal BMS.
I should have said the circuit breaker goes between the batteries and the growatt-inverter
So that is already above 48v at rest and when charging will be in the higher 50 volt range, You definately want a higher voltage breaker like the one linked above
would using a thermal fuse be applicable in your scenario? then at least you do not have to worry about voltages and can focus only on amps if I understood correctly,
